Hi all,
I'm new to Arduino microcontrollers and last week I bought an Arduino UNO r3 with an ATMEGA328P-PU processor.
I was able to create a simple circuit (with the related sketch) with a button and a LED that turns on.
What I would like to do is using it as an HID keyboard sending characters to the computer depending on buttons pressed.
I followed the instructions in mitchtech.net/arduino-usb-hid-keyboard/ and the first problem I encountered was that dfu-programmer (I'm using linux) didn't work for my processor; anyway I was able to flash the bootloader (Arduino-keyboard-0.3.hex) with avrdude using the following command:
avrdude -p m328p -P /dev/ttyACM0 -c arduino -U flash:w:Arduino-keyboard-0.3.hex -v
the output of the command seems nice
avrdude: Version 5.11.1, compiled on Oct 30 2011 at 10:37:28
Copyright (c) 2007-2009 Joerg Wunsch
System wide configuration file is "/etc/avrdude.conf"
User configuration file is "/root/.avrduderc"
User configuration file does not exist or is not a regular file, skipping
Using Port : /dev/ttyACM0
Using Programmer : arduino
AVR Part : ATMEGA328P
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PC2
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 20 4 0 no 1024 4 0 3600 3600 0xff 0xff
flash 65 6 128 0 yes 32768 128 256 4500 4500 0xff 0xff
lfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
efuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
lock 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : Arduino
Description : Arduino
Hardware Version: 3
Firmware Version: 4.4
Vtarget : 0.3 V
Varef : 0.3 V
Oscillator : 28.800 kHz
SCK period : 3.3 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.00s
avrdude: Device signature = 0x1e950f
avrdude: safemode: lfuse reads as 0
avrdude: safemode: hfuse reads as 0
avrdude: safemode: efuse reads as 0
avrdude: NOTE: FLASH memory has been specified, an erase cycle will be performed
To disable this feature, specify the -D option.
avrdude: erasing chip
avrdude: reading input file "Arduino-keyboard-0.3.hex"
avrdude: input file Arduino-keyboard-0.3.hex auto detected as Intel Hex
avrdude: writing flash (4022 bytes):
Writing | ################################################## | 100% 0.65s
avrdude: 4022 bytes of flash written
avrdude: verifying flash memory against Arduino-keyboard-0.3.hex:
avrdude: load data flash data from input file Arduino-keyboard-0.3.hex:
avrdude: input file Arduino-keyboard-0.3.hex contains 4022 bytes
avrdude: reading on-chip flash data:
Reading | ################################################## | 100% 0.52s
avrdude: verifying ...
avrdude: 4022 bytes of flash verified
avrdude: safemode: Fuses OK
avrdude done. Thank you.
but when I unplug and plug again the Arduino the command that I'm sending through the Serial.write instruction still doesn't send anything through the usb port (and I can verify through the serial console that the command is sent since if I use the ASCII code of the character (that's different respect to the HID character I have to use) I can read the character expected)
Something makes me think the bootloader has been reset to its original version since I was able to continue upload my sketches through usb and accordingly to many sites I read that shouldn't happen anymore once the new bootloader is installed.
What am I missing? Do I have to short circuit in some way the reset pin is on the board?
Sorry if the question seems stupid but as I said in the beginning I'm just a newbe..
Thanks in advance for any clue
Luca
