Arduino UNO R3 CH341
Hello all, I already found some topics here and outside this forum, but nothing worked for me. Already installed the CH341SER.EXE provided and setup my Arduino IDE to both Uno and Nano w/ Old Bootloader but no success. Also tried the AVRDUDESS 2.13 to write to it without success. The Aliexpress page says "new Starter Kit UNO R3 for arduino mini Breadboard LED jumper wire button compatile" (won't post link here to avoid trouble on my first post), the SMD is a Atmel ATMEGA328P U-KR. Here is my log:
: avrdude -u -c arduino -p m328p -P COM7 -b 115200 -B 16000000 -v -v -U flash:w:"C:\Temp\sketch_jan01a.ino.hex":i
avrdude.exe: Version 6.3, compiled on Feb 17 2016 at 09:25:53
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Users\marco\Downloads\AVRDUDESS-2.13-portable\avrdude.conf"
Using Port : COM7
Using Programmer : arduino
Overriding Baud Rate : 115200
Setting bit clk period : 16000000.0
AVR Part : ATmega328P
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PC2
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 20 4 0 no 1024 4 0 3600 3600 0xff 0xff
flash 65 6 128 0 yes 32768 128 256 4500 4500 0xff 0xff
lfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
efuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
lock 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : Arduino
Description : Arduino
avrdude.exe: stk500_getparm(): (a) protocol error, expect=0x14, resp=0x03
avrdude.exe: stk500_getparm(): (a) protocol error, expect=0x14, resp=0x10
Hardware Version: 4669920
Firmware Version: 0.4
avrdude.exe: stk500_getparm(): (a) protocol error, expect=0x14, resp=0x00
Vtarget : 420059.6 V
Varef : 198018822.4 V
Oscillator : 0.541 Hz
SCK period : 16974835.1 us
avrdude.exe: stk500_initialize(): (b) protocol error, expect=0x10, resp=0x03
avrdude.exe: initialization failed, rc=-1
Double check connections and try again, or use -F to override
this check.
avrdude.exe: stk500_disable(): protocol error, expect=0x14, resp=0x10
avrdude.exe done. Thank you.
Here is a pic of this lil brat:
Those cheap blue cables are prone to failure.
We don't mind links to the source of the purchase either but I don't think we need it in this case.
You neglected mentioning a couple of things.
Could you also take a few moments to Learn How To Use The Forum.
Other general help and troubleshooting advice can be found here.
