Arduino Uno R3 Digital Pin Output Voltage - Only 0.5V
I'm having an issue with the digital output levels on my Arduino Uno R3. When I set any of the digital output pins to "OUTPUT" in the pinMode and generate a repeating pulse, Both my oscilloscope and voltmeter are measuring 0.5V in the "high" state on every pin when programmed to the "OUTPUT" mode. Should I not be measuring something between 4 and 5 volts in the high state?
If you have something connected to those pins please post a schematic. Also post your code. Your statement indicates a fried Arduino or something not properly setup. Also check your scope prob and see if it is in X10 mode or if it is an X10 probe connected by mistook.
Thanks. The darn probe was in X10 mode. Switched it to X1 = 5.0V!
Please mark the problem solved :slight_smile:
I’m new here. I can’t see where to mark it solved.
Below every message in the topic. Select the answer that helped most. It may be your own message.
