Hello,
I’m brand new to Arduino. I’ve spent several hours this past week trying to sort this out and think it’s time I cry “Uncle” and present my issue here.
My problem started with my first project using an Elegoo starter kit. I wrote the “Blinking light Project” sketch with variations to the blink time, since my board is already blinking (LED at Pin 13). I Verified my code, then tried uploading my sketch. After about 5 minutes I got an "Error Occurred while uploading Sketch" message. I’ve since confirmed Com ports, Verbose settings, board setting, checked for pins and completed several clean installs of Arduino from the Elegoo and Arduino sites. Still no luck.
The details below are from a (real) Arduino UNO R3:
Windows 10 (4-5 year old, low milage, lots of available storage, laptop)
Arduino 1.8.13 (Clean installed from the Arduino.cc website)
Sketch book Location - C drive: …Documents/Arduino folder
Both Verbose boxes checked
Board “Arduino UNO”
Port: COM9 (ARDUINO UNO)
Programmer: AVRISP mkll
Below is my error code. This arrives after about 5 minutes of my computer trying to upload my sketch.
Could this be a timing out issue? – Dunno…
Thanks in advance! Apologies, if this is the incorrect sub forum to post this.
BB
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\bigdog 2\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\bigdog 2\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\bigdog 2\Documents\Arduino\libraries -fqbn=arduino:avr:uno -vid-pid=2341_0043 -ide-version=10813 -build-path C:\Users\BIGDOG~1\AppData\Local\Temp\arduino_build_33032 -warnings=none -build-cache C:\Users\BIGDOG~1\AppData\Local\Temp\arduino_cache_684400 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arduinoOTA.path=C:\Users\bigdog 2\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.3.0 -prefs=runtime.tools.arduinoOTA-1.3.0.path=C:\Users\bigdog 2\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.3.0 -prefs=runtime.tools.avrdude.path=C:\Users\bigdog 2\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17 -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=C:\Users\bigdog 2\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17 -prefs=runtime.tools.avr-gcc.path=C:\Users\bigdog 2\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=C:\Users\bigdog 2\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7 -verbose C:\Users\bigdog 2\Documents\Arduino\BlinkLED_Lesson1\BlinkLED_Lesson1.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\bigdog 2\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\bigdog 2\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\bigdog 2\Documents\Arduino\libraries -fqbn=arduino:avr:uno -vid-pid=2341_0043 -ide-version=10813 -build-path C:\Users\BIGDOG~1\AppData\Local\Temp\arduino_build_33032 -warnings=none -build-cache C:\Users\BIGDOG~1\AppData\Local\Temp\arduino_cache_684400 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arduinoOTA.path=C:\Users\bigdog 2\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.3.0 -prefs=runtime.tools.arduinoOTA-1.3.0.path=C:\Users\bigdog 2\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.3.0 -prefs=runtime.tools.avrdude.path=C:\Users\bigdog 2\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17 -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=C:\Users\bigdog 2\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17 -prefs=runtime.tools.avr-gcc.path=C:\Users\bigdog 2\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=C:\Users\bigdog 2\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7 -verbose C:\Users\bigdog 2\Documents\Arduino\BlinkLED_Lesson1\BlinkLED_Lesson1.ino
Using board 'uno' from platform in folder: C:\Users\bigdog 2\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.3
Using core 'arduino' from platform in folder: C:\Users\bigdog 2\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.3
Detecting libraries used...
"C:\Users\bigdog 2\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10813 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Users\bigdog 2\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.3\cores\arduino" "-IC:\Users\bigdog 2\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.3\variants\standard" "C:\Users\BIGDOG~1\AppData\Local\Temp\arduino_build_33032\sketch\BlinkLED_Lesson1.ino.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
Over character limit. To be continued...
