Arduino Uno R3 + Sparkfun Canbus Shield Project
Hello,
I'm starting this project that involves sending one CAN message to the car's canbus at specific frequency:
Car's canbus baudrate: 100kbaud
Message repeat speed: every 1 second
It's been a very long time since I tried to program something. So please assume that I am a newbie on arduino and programming.
I have bought Arduino Uno R3 + Sparkfun Canbus Shield.
Right now, all I have done is stacked up the canbus shield on top of arduino so that all the writings on the arduino and canbus shield matches up.
Is this all the connection that is needed to put arduino and canbus shield together? or do I need jumper wires to connect something else too?
Here is a picture:
Also, how would I go about programming this? I have looked at some sketches like Canbus V3, V4, but they only have the baud rate for 125k, 250k, and 500k and not 100kbaud.
Can somebody help me get started on this project?
I can sort-of help. By that I mean I may be able to guide you to the answers.
In the CANBUS world it's called "bit rate" or "bitrate" not "baud". Knowing this will help when you search.
Are you absolutely certain the bit rate is 100K? It's unusual in my experience for a manufacturer to deviate from the standard bit rates.
Yes, I'm sure that the bit rate is 100k.
Currently I'm trying to use this code. Would this work for my setup?
#include <mcp_can.h>
#include <SPI.h>
// init can bus, baudrate: 500k
unsigned char stmp[8] = {0, 1, 2, 3, 4, 5, 6, 7};
// send data: id = 0x00, standrad flame, data len = 8, stmp: data buf
CAN.sendMsgBuf(0x00, 0, 8, stmp);
delay(1000); // send data per 1000ms
How would I go about changing the bit rate from 500k to 100k?
With this code, I don't think I'm getting any message sent to the CANH & CANL ports.
I only see constant ~2.5V on CANH & CANL ports.
If there was a message being sent every second, I should see something like 2.5V to 5V to 2.5V and so on, right?
mcp_can.h
Are you using the library from here...
Yes, I'm using the library from the seeedstudio canbus shield site. Is there something that I need to change so that the code will work with the sparkfun's canbus shield?
...looks like you just need to pass CAN_100KBPS when you call CAN.begin.
I corrected my coding but still there is constant voltage ~2.5V at CANH & CANL respect to ground. Here is my code:
#include <SPI.h>
// init can bus, baudrate: 100k
CAN.begin(CAN_100KBPS);
unsigned char stmp[8] = {10, 0, 20, 0, 0, 0, 0, 0};
// send data: id = 0x430, standard flame, data length = 8, stmp: data buf
CAN.sendMsgBuf(0x430, 0, 8, stmp);
Do I have to declare something? What do I have to do to make the signal come out of the CANH & CANL ports? Am I missing something? Please let me know.
Thank you.
kpxnsfcxkp:
How are you measuring the voltage?
I'm using a multimeter to measure the voltage. I have one probe at the canh/canl and the other probe at ground of the dsub9 port. Does my code need anything else? I know I'm using a sample code from seeedstudio. Do I have to change anything to make it work with sparkfuns canbus shield?
kpxnsfcxkp:
A multimeter is not going to work. The voltage will change for a tiny fraction of a second. Neither a multimeter nor your eyeballs are fast enough to see the change.
It will be far easier to troubleshoot if you first try to receive rather than try to transmit.
Is the bus in question fairly active?
What are you trying to control?
As far as I can tell, it's the same CAN controller (MCP2515) at the same clock speed (16 MHz) so, assuming the library is fairly bug-free, the library and your code should be fine.
Yes, the bus is fairly active as I will be connecting to a CANBUS in a car.
I will first try to receive the data like you have advised.
I'm trying to disable the daytime running light on my car.
The Sparkfun Shield works great with the sending example, also with extended messages. But I can't receive anything and I don't know why...
I want to receive extended messages at a J1939 CAN-bus (250k), do I have to change something? I think the attachInterrupt 0 should be ok (pin D2), but I don't get an interrupt. I have a CAN-analyzer, so I'm sure that there are some active messages. Can anyone help me?
// demo: CAN-BUS Shield, receive data
#include "mcp_can.h"
#include <SPI.h>
#include <stdio.h>
#define INT8U unsigned char
INT8U Flag_Recv = 0;
INT8U len = 0;
INT8U buf[8];
char str[20];
  CAN.begin(CAN_250KBPS);                   // init can bus : baudrate = 250k
  attachInterrupt(0, MCP2515_ISR, FALLING); // start interrupt
  Serial.println("rdy");
void MCP2515_ISR()
     Flag_Recv = 1;
     Serial.println("Interrupt");
    if(Flag_Recv)                   // check if get data
      Flag_Recv = 0;                // clear flag
      CAN.readMsgBuf(&len, buf);    // read data,  len: data length, buf: data buf
      Serial.println("CAN_BUS GET DATA!");
      Serial.print("data len = ")
      Serial.println(len);
      for(int i = 0; i<len; i++)    // print the data
        Serial.print(buf[i]); Serial.print("\t");
Edit:
I have sended via a CAN-analyzer messages in standard format and I can receive them correctly! So it seems that only extended messages will be ignored... :frowning:
@kpxnsfcxkp
I don't have changed anything at the send example, only the baudrate and it works with the Sparkfun shield. Do you have connected it at the correct contacts, 3 and 5?
Hi
did you add a 120ohm resistor connected in parallel with CANL and CANH?
Hello, I'm actually new on arduino and I'm doing a similar project discussed in this thread. Does anyone know how to data log can bus data into a sd card with the can bus shield? Thanks for the help
Hi guys! You can assume me a newbie on arduino and all these programming stuff. I desperately need your help right now. For my final project i'm trying to do that project. I've got uno r3, canbus shield, serial LCD and gps module. As programme i was using skpang demo code, but it didn't work out. When i connect obd 2 cable to my vehicle the programme is working but as result i didn't see anything. Just " can init ok" after that nothing happened. Thanks for your help.
Hi guys! You can assume me a newbie on arduino and all these programming stuff. I desperately need your help right now. For my final project i'm trying to do that project. I've got uno r3, canbus shield, serial LCD and gps module. As programme i was using sparkfun demo code, but it didn't work out. When i connect obd 2 cable to my vehicle the programme is working but as result i didn't see anything. Just " can init ok" after that nothing happened. Thanks for your help.
Hi all
I am new to Arduino and i try to use it to check dashes of car and ecu on bench for repairing, if i run exampale for recive i can get the messages, but every time i am try to copy some other codes to run to transmit message i get this error "Arduino: 1.6.7 (Windows 7), Board: "Arduino/Genuino Uno"
C:\Users\User\Documents\Arduino\sketch_dec23a\sketch_dec23a.ino: In function 'void setup()':
sketch_dec23a:14: error: redefinition of 'void setup()'
sketch_dec23a:1: error: 'void setup()' previously defined here
C:\Users\User\Documents\Arduino\sketch_dec23a\sketch_dec23a.ino: In function 'void loop()':
sketch_dec23a:22: error: redefinition of 'void loop()'
sketch_dec23a:6: error: 'void loop()' previously defined here
Multiple libraries were found for "mcp_can.h"
Used: D:\Program Files\Arduino\libraries\CAN_BUS_Shield1
Not used: D:\Program Files\Arduino\libraries\CAN_BUS_Shield
exit status 1
enabled in File > Preferences.
any help i playing with this sercal days already.
Thanks
