Hi
My setup : Macbook Pro 2.4Ghz Intel Core 2 duo, RAM 4Go, OSX.6.8, Arduino Uno R3
The first tries were perfectly all right. When plugged the Uno, the OS asked for what to do with the new device. I said OK, then the device could be seen in the network prefs list. Then the tests went well with the Arduino IDE, blink test, serial test, uploaded and working successfully. Then I launched some Max patches Arduino2Max and Maxuino. Nothing happened, but may be I was missing something. Then I tried some other things : attaching a servo, running the sweep example. Nothing happened.
Then now, the device won't show anymore wherever (no /dev/tty.usbmodem***), even tried on a PC Vista, the PC did not ask for anything on plugging the Uno.
The tx/rx transmitting LEDs don't blink anymore.
How will I be able to conquer the universe in these harsh conditions ?
On my windows 7 system, I use control panel and then device manager and it appears under Ports not USB devices.
The serial port com number keeps changing around. The IDE loses track and keeps trying to talk to my mouse instead. I get into these complicated cycles of unplugging and pluging the USB cable, starting and restarting the Arduino IDE, and if it gets too difficult, rebooting the computer.
Sometimes the device manager says the arduino is COM4 but the IDE only gives me a choice of COM3.
It seems to be different every time, but always comes good eventually.
Well, are you suggesting something is burnt and needs replacement ? Because I had the same symptoms with a brand new Arduino Fio.... Doing nothing else than just plugging it in.
..BUT the usb plug works well when plugging in a mouse.
