Arduino UNO R4 Minima - I can send keystrokes, or I can control a stepper motor. But I can't do both things in the same sketch
Hi @Delta_G and thank you for your suggestion to post the full code. Please find it here.
I didn't post it before because I was hoping that someone who incurred in the same problem may enlighten me with answers about general compatibility issues between keyboard.h and accelStepper.h.
Here is the full code: again, if I omit including keyboard.h and the keyboard-related lines from the very same code, I can control the stepper by sending keys from the serial monitor as usual.
Many thanks for your help.
Cesare
Stepper-based microscope Z-stage
Circuit and comments:
See http://www.cesarebrizio.it/Arduino/Z-Stage.html
Circuit is as illustrated here:
https://www.tdegypt.com/wp-content/uploads/2017/08/stepper-motor-wiring.png
the only exception being that the sketch uses digital outputs 4 - 5 - 6 - 7
while the Fritzing diagram uses digital outputs 8 - 9 - 10 - 11
 created 9 Jan 2021
 modified 9 Feb 2024 - added a "send keyboard press after each step"
 by Cesare Brizio
This example code is in the public domain.
This sketch controls the rotation of the knob of a microscope Z-stage
based on a stepper motor and custom-made mechanical coupling.
Stepper model is 28BYJ48, controlled via the X113647 Stepper Motor
Driver (based on the ULN2003A IC) normally purchased with the stepper.
The knob can rotate 360 degrees in both direction.
Commands for incremental rotation are provided.
The platform is managed by serial dialogue, managed via Serial Monitor
or Tera Term.
The following commands are implemented:
---> continuous rotation
R = Rotate clockwise continuously (meaning: for several turns)
L = Rotate counter-clockwise continuously (meaning: for several turns)
S = Stop rotating
---> 360° continuous rotation
r = Rotate for 360° clockwise
l = Rotate for 360° counter-clockwise
---> rotation by small increments
k = rotate 4° clockwise
K = rotate 4° counter-clockwise
f = rotate 5° clockwise
F = rotate 5° counter-clockwise
t = rotate 10° clockwise
T = rotate 10° counter-clockwise
w = rotate 20° clockwise
W = rotate 20° counter-clockwise
q = rotate 40° clockwise
Q = rotate 40° counter-clockwise
It's very obvious that the source code could be optimized, but I preferred to keep
a repetitive structure with a separate IF for each possible value of incomingByte.
Sources of information:
Small stepper control: http://arduino-info.wikispaces.com/SmallSteppers
/*-----( Import needed libraries )-----*/
#include <AccelStepper.h>
#include <Keyboard.h> // Needed only if keyboard stroke is to be sent (REQUIRES Arduino UNO R4 Minima)
/*-----( Declare Constants and Pin Numbers )-----*/
/* NEVER PUT ; AFTER A #define statement!!!! */
// motor pins
#define motorPin1  4     // Blue   - 28BYJ-48 pin 1
#define motorPin2  5     // Pink   - 28BYJ-48 pin 2
#define motorPin3  6     // Yellow - 28BYJ-48 pin 3
#define motorPin4  7     // Orange - 28BYJ-48 pin 4
                        // Red    - 28BYJ-48 pin 5 (VCC)
                        // Blue   - 28BYJ-48 pin GND
#define STEPS_PER_TURN 2048 // number of steps in 360°
#define STEPS_PER_FOUR 22 // number of steps in 4°
#define STEPS_PER_FIVE 28 // number of steps in 5°
#define STEPS_PER_TEN 57 // number of steps in 10°
#define STEPS_PER_TWENTY 114 // number of steps in 20°
#define STEPS_PER_FORTY 228 // number of steps in 40°
int motorSpeed = 500; // High speeds (800 and above) may cause erratic behavior in 28BYJ-48
int motorAccel = 400; // As above: better avoiding extreme accelerations
int myPos = 0; // will be used to define a starting point for 360° rotations
int LeftTurnUp = 0; // Couple of flags to determine rotation direction
int RightTurnDown = 0; // Couple of flags to determine rotation direction
int Continuous = 2; // used below to discriminate single rotation commands
// Continuous will be set to 1 or 0 only when a valid command character will be received
int incomingByte = 0; // for incoming serial data
int STEPS_TO_DO = 0; // to allocate the number of steps needed to perform the required rotation
/*-----( Objects for stepper control )-----*/
// Set up the stepper as 4 wire bipolar on pin 4,5,6,7
// NOTE: The sequence 1-3-2-4 is required for proper sequencing of 28BYJ48
AccelStepper stepper(4,motorPin1,motorPin3,motorPin2,motorPin4);
  stepper.setMinPulseWidth(20); // Advisable setting to avoid that pulses from Arduino
                                // are too quick to be decoded
  stepper.setMaxSpeed(motorSpeed);
  stepper.setSpeed(motorSpeed);
  stepper.setAcceleration(motorAccel);
  // the following two lines reset "step zero" to the current position
  stepper.setCurrentPosition(stepper.currentPosition());
  stepper.runToPosition();
  Serial.println("Available commands:");
  Serial.println("====> Continuous rotation");
  Serial.println("R = continuous clockwise rotation");
  Serial.println("L = continuous counter-clockwise rotation");
  Serial.println("S = stop rotation");
  Serial.println("====> 360° Rotation");
  Serial.println("o = 360° clockwise rotation");
  Serial.println("O = 360° counter-clockwise rotation");
  Serial.println("====> Rotation by small increments");
  Serial.println("k = rotate 4° clockwise");
  Serial.println("K = rotate 4° counter-clockwise");
  Serial.println("f = rotate 5° clockwise");
  Serial.println("F = rotate 5° counter-clockwise");
  Serial.println("t = rotate 10° clockwise");
  Serial.println("T = rotate 10° counter-clockwise");
  Serial.println("w = rotate 20° clockwise");
  Serial.println("W = rotate 20° counter-clockwise");
  Serial.println("q = rotate 40° clockwise");
  Serial.println("Q = rotate 40° counter-clockwise");
  Keyboard.begin(); // required to initialize the communication with the keyboard
  if (Serial.available() > 0)
    Serial.println("Serial.available() > 0");
    incomingByte = Serial.read();
    Serial.print("Received ");
    Serial.println(incomingByte);
      if (incomingByte == 'R')
        Serial.println("received «R» - activating continuous clockwise rotation");
        // The two lines that follow allow to send commands in any sequence:
        // before execution, a quick stop is performed
        stepper.stop(); // Stop as fast as possible: sets new target
        stepper.runToPosition(); // Now stopped after quickstop
        // The following couple of flags determines rotation direction
        LeftTurnUp = 0;
        RightTurnDown = 1;
        Continuous = 1; // used below to discriminate single rotation commands
        stepper.setCurrentPosition(stepper.currentPosition()); // Set step 0 "here"
        stepper.setSpeed(motorSpeed); // Previous commands have reset the speed
      if (incomingByte == 'L')
        Serial.println("received «L» - activating continuous counter-clockwise rotation");
        RightTurnDown = 0;
        LeftTurnUp = 1;
      if (incomingByte == 'S')
        Serial.println("received «S» - stopping rotation");
        // Reset the flags that determine rotation direction
        LeftTurnUp = 0;
        RightTurnDown = 0;
      if (incomingByte == 'o')
        Serial.println("received «o» - activating single clockwise rotation");
        LeftTurnUp = 0;
        RightTurnDown = 1;
        Continuous = 0; // used below to discriminate single rotation commands
        // Since I will have to step forward 2047 steps, I store my current
        // position as starting point of the rotation
        myPos=stepper.currentPosition();
        STEPS_TO_DO = STEPS_PER_TURN;
      if (incomingByte == 'O')
        Serial.println("received «O» - activating single counter-clockwise rotation");
        RightTurnDown = 0;
        LeftTurnUp = 1;
        // Since I will have to step backwards 2047 steps, I store my current
      if (incomingByte == 'k')
        Serial.println("received «k» - activating 4° clockwise rotation");
        LeftTurnUp = 0;
        RightTurnDown = 1;
        // Since I will have to step forward STEPS_PER_FIVE steps, I store my current
        STEPS_TO_DO = STEPS_PER_FOUR;
      if (incomingByte == 'K')
        Serial.println("received «K» - activating 4° counter-clockwise rotation");
        RightTurnDown = 0;
        LeftTurnUp = 1;
        // Since I will have to step backwards STEPS_PER_FIVE steps, I store my current
      if (incomingByte == 'f')
        Serial.println("received «f» - activating 5° clockwise rotation");
        LeftTurnUp = 0;
        RightTurnDown = 1;
        STEPS_TO_DO = STEPS_PER_FIVE;
      if (incomingByte == 'F')
        Serial.println("received «F» - activating 5° counter-clockwise rotation");
        RightTurnDown = 0;
        LeftTurnUp = 1;
      if (incomingByte == 't')
        Serial.println("received «t» - activating 10° clockwise rotation");
        LeftTurnUp = 0;
        RightTurnDown = 1;
        // Since I will have to step forward STEPS_PER_TEN steps, I store my current
        STEPS_TO_DO = STEPS_PER_TEN;
      if (incomingByte == 'T')
        Serial.println("received «T» - activating 10° counter-clockwise rotation");
        RightTurnDown = 0;
        LeftTurnUp = 1;
        // Since I will have to step backwards STEPS_PER_TEN steps, I store my current
      if (incomingByte == 'w')
        Serial.println("received «w» - activating 20° clockwise rotation");
        LeftTurnUp = 0;
        RightTurnDown = 1;
        // Since I will have to step forward STEPS_PER_TWENTY steps, I store my current
        STEPS_TO_DO = STEPS_PER_TWENTY;
      if (incomingByte == 'W')
        Serial.println("received «W» - activating 20° counter-clockwise rotation");
        RightTurnDown = 0;
        LeftTurnUp = 1;
        // Since I will have to step backwards STEPS_PER_TWENTY steps, I store my current
      if (incomingByte == 'q')
        Serial.println("received «q» - activating 40° clockwise rotation");
        LeftTurnUp = 0;
        RightTurnDown = 1;
        STEPS_TO_DO = STEPS_PER_FORTY;
      if (incomingByte == 'Q')
        Serial.println("received «Q» - activating 40° counter-clockwise rotation");
        RightTurnDown = 0;
        LeftTurnUp = 1;
  if (Continuous == 1) // continuous rotation
    Serial.println("=================================================================");
    Serial.println("     Variables status before attempting stepper activation");
    Serial.print("incomingByte ");
    Serial.print("Continuous ");
    Serial.println(Continuous);
    Serial.print("myPos ");
    Serial.println(myPos);
    Serial.print("STEPS_TO_DO ");
    Serial.println(STEPS_TO_DO);
    if (LeftTurnUp == 1)  //left turn
        stepper.moveTo(10000); //move many steps - more then mechanical needed
    if (RightTurnDown == 1)  //right turn
        stepper.moveTo(-10000); //move many steps - more then mechanical needed
    stepper.run();
    Serial.println("THAT ONE - You have 10 seconds to change the active window. Keystroke will be sent to the foreground program window.");
    delay(10000);
    Keyboard.press(KEY_F1);
    delay(100);
    Keyboard.releaseAll();
    Continuous = 2; // If Continuous is not 1 nor 0, any input different than those admissible will not enter this "If"
    incomingByte = '-';  // IncomingByte is assigned a spurious value to ensure that the current value is not recycled
  if (Continuous == 0) // partial rotation
        stepper.moveTo(myPos+STEPS_TO_DO); // number of  steps in 5, 10, 20 or 360°
       stepper.moveTo(myPos-STEPS_TO_DO); // number of  steps in 5, 10, 20 or 360°
    stepper.run();
    Serial.println("THIS ONE - You have 10 seconds to change the active window. Keystroke will be sent to the foreground program window.");
    delay(10000);
    delay(100);
