Arduino UNO R4 WiFi + Google Sheets
I am using a battery powered Arduino UNO R4 WiFi which is interfaced with phone through IoT. Is there a means to write the data from Arduino to Google Sheets. FYI - I will not have access to PC and hence no serial monitor.
Thanks is advance for the help and guidance
Hello, @johnchugh
You can log data from your Arduino to Google Sheets without using a PC or serial monitor. Here are a couple of approaches you can explore:
ESP32 Datalogging to Google Sheets (Google Service Account):
Use an ESP32 board (similar to Arduino) to securely and reliably log data to Google Sheets.
Set up a Google Service Account, create a Google project, and associate the service account with that project.
Follow the steps outlined in the tutorial to save temperature, humidity, pressure, and timestamps on a Google spreadsheet.
ESP8266 Tutorial: Logging Data to Google Sheets:
If you’re using an ESP8266 (NodeMCU), you can follow a step-by-step tutorial to log data directly to a Google Sheets spreadsheet.
Hope this work for you.
Best regards,
thomas945
