However, when I am pushing any one of the push-buttons SW1 or SW2, the corresponding function swt_afunc() or swt_bfunc() respectively runs twice instead of once.
My questions are the following:
Do I need to add a buffer between the Arduino Pins 2 and 3 and the push-switches?
Is my code for initializing the Interrupts okay?
What is going wrong about running two times per push?
I'm not too familiar with interrupts on Arduino, but the initialization looks correct to me.
On the other hand, I believe your problem about the ISR running twice a button press is with how you process the button presses. Have you "debounced" the buttons? If not, what's probably happening is that when you press the button, the contacts within the button will literally bounce, causing multiple "fake" button presses. If you are polling the button fast enough without the debouncing code, the program will think the button was pressed more times than it really was.
Pushbuttons are one thing that should almost never be serviced by interrupts. There is simply no reason to do so; it generally indicates that your code is not properly written.
De-bouncing is just one reason not to do so.
Power_Broker:
Polling is one thing, but instantaneous response using interrupts (properly) is even more guaranteed to cause debounce problems.
Yes and no. It's a very inaccurate way of denouncing. You need to be 100% sure that the button has stabilized before moving on instead of guessing the amount of time it takes to stabilize.
Power_Broker:
My point precisely, which is why I did not comment on it.
I prefer "ironclad" code which continuously checks the state.
My contribution to the art:
// Blink without "delay()" - multi! With button de-bounce.
const int led1Pin = 13; // LED pin number
const int led2Pin = 10;
const int led3Pin = 11;
const int button1 = 4; // buttons & switches always connect from input to ground
int led1State = LOW; // initialise the LED
int led2State = LOW;
int led3State = LOW;
char bstate1 = 0;
unsigned long count1 = 0; // will store last time LED was updated
unsigned long count2 = 0;
unsigned long count3 = 0;
unsigned long bcount1 = 0; // button debounce timer. Replicate as necessary.
// Have we completed the specified interval since last confirmed event?
// "marker" chooses which counter to check
boolean timeout(unsigned long *marker, unsigned long interval) {
if (millis() - *marker >= interval) {
*marker += interval; // move on ready for next interval
return true;
else return false;
// Deal with a button read; true if button pressed and debounced is a new event
// Uses reading of button input, debounce store, state store and debounce interval.
boolean butndown(char button, unsigned long *marker, char *butnstate, unsigned long interval) {
switch (*butnstate) { // Odd states if was pressed, >= 2 if debounce in progress
case 0: // Button up so far,
if (button == HIGH) return false; // Nothing happening!
else {
*butnstate = 2; // record that is now pressed
*marker = millis(); // note when was pressed
return false; // and move on
case 1: // Button down so far,
if (button == LOW) return false; // Nothing happening!
else {
*butnstate = 3; // record that is now released
*marker = millis(); // note when was released
case 2: // Button was up, now down.
if (button == HIGH) {
*butnstate = 0; // no, not debounced; revert the state
return false; // False alarm!
else {
*butnstate = 1; // jackpot! update the state
return true; // because we have the desired event!
return false; // not done yet; just move on
case 3: // Button was down, now up.
if (button == LOW) {
*butnstate = 1; // no, not debounced; revert the state
else {
*butnstate = 0; // Debounced; update the state
return false; // but it is not the event we want
default: // Error; recover anyway
*butnstate = 0;
return false; // Definitely false!
pinMode(led1Pin, OUTPUT);
pinMode(led2Pin, OUTPUT);
pinMode(led3Pin, OUTPUT);
pinMode(button1, INPUT);
digitalWrite(button1,HIGH); // internal pullup all versions
// Toggle LED if button debounced
if (butndown(digitalRead(button1), &bcount1, &bstate1, 10UL )) {
if (led1State == LOW) {
led1State = HIGH;
else {
led1State = LOW;
digitalWrite(led1Pin, led1State);
// Act if the latter time (ms) has now passed on this particular counter,
if (timeout(&count2, 300UL )) {
if (led2State == LOW) {
led2State = HIGH;
else {
led2State = LOW;
digitalWrite(led2Pin, led2State);
if (timeout(&count3, 77UL )) {
if (led3State == LOW) {
led3State = HIGH;
else {
led3State = LOW;
digitalWrite(led3Pin, led3State);
