Arduino Uno rev3 with RTC and 2 servos attached how many amps?
Hi to all, I just managed to finish a project for arduino, a ds1307(RTC) and 2 servos are attached to Arduino but I don't know how many amperes would be fine to power it with. Voltage is about 12V ok. Amperes how much?
thank you in advance for replies,
George
That depends 90% on how much the servos need, and I can't see that from here...
fungus:
the 2 servos are: http://www.servocity.com/html/hs-422_super_sport_.html
it says
Current Drain (4.8V): 8mA/idle and 150mA no load operating
Current Drain (6.0V): 8.8mA/idle and 180mA no load operating
will it be ok to power arduino with 12V / 2A power supply?
blades:
fungus:
it says
Maybe, it all depends on what's attached to the servos. Those servos can draw more than 1A each under heavy load.
fungus:
blades:
fungus:
it says
it's just a Logitech webcam attached at servos, perhaps 30-50gramms
The only way to know is to put in a multimeter and watch the amps as you move it around.
fungus:
ok where to put the multimeters pins and where to put multimeters switch?
