please help was working one minute then the next minute i get the error code
enabled in File > Preferences.
Arduino: 1.0.6 (Windows 7), Board: "Arduino Uno"
Binary sketch size: 2,456 bytes (of a 32,256 byte maximum)
processing.app.SerialNotFoundException: Serial port 'COM3' not found. Did you select the right one from the Tools > Serial Port menu?
at processing.app.Serial.(Serial.java:191)
at processing.app.Serial.(Serial.java:77)
at processing.app.debug.Uploader.flushSerialBuffer(Uploader.java:77)
at processing.app.debug.AvrdudeUploader.uploadViaBootloader(AvrdudeUploader.java:175)
at processing.app.debug.AvrdudeUploader.uploadUsingPreferences(AvrdudeUploader.java:67)
at processing.app.Sketch.upload(Sketch.java:1666)
at processing.app.Sketch.exportApplet(Sketch.java:1622)
at processing.app.Sketch.exportApplet(Sketch.java:1594)
at processing.app.Editor$DefaultExportHandler.run(Editor.java:2382)
at java.lang.Thread.run(Thread.java:619)
the serial port also is grayed out please tell me what to do and in the device manager the 'ports' selection dosent show up i have a windows 7
ChilliTronix:
Does the board get power when it is plugged it?
Any noises made by the computer when something is plugged in?
Ok, I know this is an older post, but hopefully I can still get an answer, because I can't seem to find it googling the issue.
So, my Arduino UNO R3 is not recognized by Windows, the same exact problem as bocaj78 - "com3 not found".
Changing ports does nothing, restarting does nothing, changing cables does nothing. Does not show up in devices, unknown or otherwise, nor does it make a noise when connected.
It seems, based on forums/articles I've read that I have to reset the Arduino.
I suggest trying to connect it to a different computer and see if it is recognized. If it does not show as a device to the other computer, you may need to re-flash the firmware on the ATmega16U2 using an ISP programmer or another Arduino as ISP.
