Arduino UNO + RFM22B + RadioHead library communication problem
Hello.
I’m trying to connect two UNOs with two RFM22Bs. The RFM22Bs are DIP, like the linked but 433mhz, without any shield (using a prototyping board). They’re connected the way it’s described in the RadioHead library by mikem (RH_RF22.h header). All required Arduino outputs go through a voltage divider (AFAICT). Additionally, the shutdown pin is connected to D3 (unused ATM).
I’m trying to get the rf22 reliable datagram client/server example working. Made some code changes.
The code for server:
// RH22 reliable datagram server
#include <RH_RF22.h>
#include <RHReliableDatagram.h>
#define CLIENT_ADDRESS 9
#define SERVER_ADDRESS 1
RH_RF22 driver(10, 2);
RHReliableDatagram manager(driver, SERVER_ADDRESS);
void setup(void)
  randomSeed(analogRead(0));
  if (manager.init())
    Serial.println("RFM22B SERVER init OK");
    Serial.println("RFM22B SERVER init FAIL");
uint8_t data[] = "And hello back to you";
uint8_t buf[RH_RF22_MAX_MESSAGE_LEN];
void loop(void)
  if (manager.available())
    uint8_t len = RH_RF22_MAX_MESSAGE_LEN;
    uint8_t from;
    for (uint8_t i = 0; i < len; ++i)
      buf[i] = random(65,87);
    if (manager.recvfromAckTimeout(buf, &len, 2000, &from))
      Serial.print("got request from : 0x");
      Serial.print(from, HEX);
      Serial.print(": ");
      Serial.println((char*)buf);
      if (manager.sendtoWait(data, sizeof(data), from))
        Serial.println("sendtoWait OK");
        Serial.println("sendtoWait FAIL");
      Serial.println("no MSG");
   Serial.println("UNAVAILABLE");
 delay(200);
And the code for the client:
RHReliableDatagram manager(driver, CLIENT_ADDRESS);
  if (manager.init())
    Serial.println("RFM22B CLIENT init OK");
    Serial.println("RFM22B CLIENT init FAIL");
uint8_t data[] = "Hello World!";
  Serial.println("Sending to rf22_reliable_datagram_server");
  if (manager.sendtoWait(data, sizeof(data), SERVER_ADDRESS))
    uint8_t from;
      Serial.print("got reply from : 0x");
      Serial.print(": ");
      Serial.println("No reply, is rf22_reliable_datagram_server running?");
    Serial.println("sendtoWait FAIL; trying receive");
    uint8_t from;
      Serial.println("received");
  delay(3000);
The problem is that it works… for a short while.
The server prints this:
UNAVAILABLE
UNAVAILABLE
UNAVAILABLE
UNAVAILABLE
UNAVAILABLE
got request from : 0x9: Hello World!
sendtoWait OK
DATA: And hello back to you
UNAVAILABLE
UNAVAILABLE
UNAVAILABLE
UNAVAILABLE
UNAVAILABLE
UNAVAILABLE
UNAVAILABLE
UNAVAILABLE
UNAVAILABLE
UNAVAILABLE
UNAVAILABLE
UNAVAILABLE
UNAVAILABLE
UNAVAILABLE
UNAVAILABLE
sendtoWait OK
UNAVAILABLE
UNAVAILABLE
UNAVAILABLE
UNAVAILABLE
UNAVAILABLE
UNAVAILABLE
UNAVAILABLE
UNAVAILABLE
UNAVAILABLE
UNAVAILABLE
UNAVAILABLE
UNAVAILABLE
UNAVAILABLE
UNAVAILABLE
UNAVAILABLE
…then it hangs (i suspect in sendToWait). The client seem to work without hanging (and if i reset the server, both work again for a while):
sendtoWait OK
got reply from : 0x1: And hello back to you
sendtoWait OK
sendtoWait OK
sendtoWait OK
got reply from : 0x1:  you
sendtoWait FAIL
Also, as the client log shows, messages become garbage after a while. Anyone has idea if this is a hardware / software problem and how to debug this ? I have some experience with programming but only basic with electronics (and none with radio related electronics).
Thanks
