I have a project in which a sinusoidal voltage is measured using Arduino UNO and the data should be saved in a text file that contains the measured voltage and the time ( or index) in which each reading is taken.
I already have the code that measures the voltage, which I got from Arduino examples.
As shown below:
ReadAnalogVoltage
Reads an analog input on pin 0, converts it to voltage, and prints the result to the serial monitor.
Attach the center pin of a potentiometer to pin A0, and the outside pins to +5V and ground.
This example code is in the public domain.
// the setup routine runs once when you press reset:
// initialize serial communication at 9600 bits per second:
// the loop routine runs over and over again forever:
// read the input on analog pin 0:
int sensorValue = analogRead(A0);
// Convert the analog reading (which goes from 0 - 1023) to a voltage (0 - 5V):
float voltage = sensorValue * (5.0 / 1023.0);
// print out the value you read:
Serial.println(voltage);
My question is that is there any way to set the sampling rate to be 2400 samples/s ?
Also how can I save each reading in a text file?
I would be grateful if anyone could help me.
Regards,
