Arduino Uno+SD Shield+XBee Digi
Hi
-Arduino Uno
-Wireless SD Shield
-XBee - Digi International - model XBee2. Modem type = XB24-ZB
-470uf Capacitor
I am trying to make the XBee discover my network.
  1. I have connected the Capacitor to XBee pin 10 and pin 1.
  2. updloaded an epmty sketch to Arduino:
void setup() { }
void loop() { }
  1. Run X-CTU and upgraded XBee firmware.
What do I do next? When trying to run Arduino sketches to discover my network I get a message “Shield not present”. For instance:
 This example  prints the Wifi shield's MAC address, and
 scans for available Wifi networks using the Wifi shield.
 Every ten seconds, it scans again. It doesn't actually
 connect to any network, so no encryption scheme is specified.
 Circuit:
 * WiFi shield attached
 created 13 July 2010
 by dlf (Metodo2 srl)
 modified 21 Junn 2012
 by Tom Igoe and Jaymes Dec
#include <SPI.h>
#include <WiFi.h>
  //Initialize serial and wait for port to open:
  while (!Serial) {
    ; // wait for serial port to connect. Needed for Leonardo only
  // check for the presence of the shield:
  if (WiFi.status() == WL_NO_SHIELD) {
    Serial.println("WiFi shield not present");
    // don't continue:
    while(true);
  // Print WiFi MAC address:
  printMacAddress();
  // scan for existing networks:
  Serial.println("Scanning available networks...");
  listNetworks();
  delay(10000);
  listNetworks();
void printMacAddress() {
  // the MAC address of your Wifi shield
  byte mac[6];
  // print your MAC address:
  WiFi.macAddress(mac);
  Serial.print("MAC: ");
  Serial.print(mac[5],HEX);
  Serial.print(":");
  Serial.print(mac[4],HEX);
  Serial.print(":");
  Serial.print(mac[3],HEX);
  Serial.print(":");
  Serial.print(mac[2],HEX);
  Serial.print(":");
  Serial.print(mac[1],HEX);
  Serial.print(":");
  Serial.println(mac[0],HEX);
void listNetworks() {
  // scan for nearby networks:
  Serial.println("** Scan Networks **");
  int numSsid = WiFi.scanNetworks();
  if (numSsid == -1)
    Serial.println("Couldn't get a wifi connection");
    while(true);
  // print the list of networks seen:
  Serial.print("number of available networks:");
  Serial.println(numSsid);
  // print the network number and name for each network found:
  for (int thisNet = 0; thisNet<numSsid; thisNet++) {
    Serial.print(thisNet);
    Serial.print(") ");
    Serial.print(WiFi.SSID(thisNet));
    Serial.print("\tSignal: ");
    Serial.print(WiFi.RSSI(thisNet));
    Serial.print(" dBm");
    Serial.print("\tEncryption: ");
    printEncryptionType(WiFi.encryptionType(thisNet));
void printEncryptionType(int thisType) {
  // read the encryption type and print out the name:
  switch (thisType) {
  case ENC_TYPE_WEP:
    Serial.println("WEP");
  case ENC_TYPE_TKIP:
    Serial.println("WPA");
  case ENC_TYPE_CCMP:
    Serial.println("WPA2");
  case ENC_TYPE_NONE:
    Serial.println("None");
  case ENC_TYPE_AUTO:
    Serial.println("Auto");
I would appreciate your help!
What do I do next? When trying to run Arduino sketches to discover my network I get a message "Shield not present". For instance:
Not surprising, since the library expects you to have an official WiFi shield.
The XBee you list is [u]not[/u] a WiFi device.
