Hello,
i have problem with sending temp data (ds18b20)via enc28j60. If i use sensor BMP085, all works.
There is main code:
- Arduino receive IP address from DHCP and then frozen is it
#include <OneWire.h>
#include <EtherCard.h>
OneWire ds(2); // on pin 10
// ethernet interface mac address, must be unique on the LAN
static byte mymac[] = { 0x74,0x69,0x69,0x2D,0x30,0x31 };
byte Ethernet::buffer[700];
static uint32_t timer;
char website[] PROGMEM = "192.168.1.37";
// called when the client request is complete
static void my_callback (byte status, word off, word len) {
Serial.println(">>>");
Ethernet::buffer[off+300] = 0;
Serial.print((const char*) Ethernet::buffer + off);
Serial.println("...");
void setup(void) {
if (ether.begin(sizeof Ethernet::buffer, mymac) == 0)
Serial.println( "Failed to access Ethernet controller");
if (!ether.dhcpSetup())
Serial.println("DHCP failed");
ether.printIp("IP: ", ether.myip);
ether.printIp("GW: ", ether.gwip);
ether.printIp("DNS: ", ether.dnsip);
if (!ether.dnsLookup(website))
Serial.println("DNS failed");
ether.printIp("SRV: ", ether.hisip);
void loop(void) {
byte i;
byte present = 0;
byte type_s;
byte data[12];
byte addr[8];
float celsius, fahrenheit;
if ( !ds.search(addr)) {
ds.reset_search();
delay(250);
return;
for( i = 0; i < 8; i++) {
if (OneWire::crc8(addr, 7) != addr[7]) {
return;
switch (addr[0]) {
case 0x10:
type_s = 1;
case 0x28:
type_s = 0;
case 0x22:
type_s = 0;
default:
return;
ds.reset();
ds.select(addr);
ds.write(0x44,1); // start conversion, with parasite power on at the end
delay(1000); // maybe 750ms is enough, maybe not
// we might do a ds.depower() here, but the reset will take care of it.
present = ds.reset();
ds.select(addr);
ds.write(0xBE); // Read Scratchpad
for ( i = 0; i < 9; i++) { // we need 9 bytes
data[i] = ds.read();
// convert the data to actual temperature
unsigned int raw = (data[1] << 8) | data[0];
if (type_s) {
raw = raw << 3; // 9 bit resolution default
if (data[7] == 0x10) {
raw = (raw & 0xFFF0) + 12 - data[6];
byte cfg = (data[4] & 0x60);
if (cfg == 0x00) raw = raw << 3; // 9 bit resolution, 93.75 ms
else if (cfg == 0x20) raw = raw << 2; // 10 bit res, 187.5 ms
else if (cfg == 0x40) raw = raw << 1; // 11 bit res, 375 ms
celsius = (float)raw / 16.0;
Serial.print("Temperature = ");
Serial.print(celsius);
Serial.print(" Celsius ");
ether.packetLoop(ether.packetReceive());
float stupen = celsius; // or whatever
char tempik[7];
dtostrf(stupen, 5, 2,tempik);
if (millis() > timer) {
timer = millis() + 10000;
ether.browseUrl(PSTR("/temper.php?temp="),tempik, website, NULL);
please help
