I am building a project that utilizes one Arduino UNO as a master controller that monitors six different voltage inputs and depending on the value of each input, it will energize or de-energize two outputs per input (12 outputs total). However, I am running into an issue where my Arduino is only detecting one input and disregarding the others. For example, I have A0 corresponding to D0 and D1. When A0 is above the set point, D0 and D1 are both high. However, For A1 - A5, the associated outputs (D2 - D11) are not doing anything. I'm fairly new to coding with the Arduino, so I was wondering if someone could take a look at what I have and see if there is something I am missing.
// Voltage Input to Arduino
const int analogInPin1 = A0;
const int analogInPin2 = A1;
const int analogInPin3 = A2;
const int analogInPin4 = A3;
const int analogInPin5 = A4;
const int analogInPin6 = A5;
// Assigning the Ouputs to the Relays
const int R1 = 0; // Relay 1
const int R2 = 1; // Relay 2
const int R3 = 2; // Relay 3
const int R4 = 3; // Relay 4
const int R5 = 4; // Relay 5
const int R6 = 5; // Relay 6
const int R7 = 6; // Relay 7
const int R8 = 7; // Relay 8
const int R9 = 8; // Relay 9
const int R10 = 9; // Relay 10
const int R11 = 10; // Relay 11
const int R12 = 11; // Relay 12
// Initial States of Inputs/Outputs & Establishing the SetPoint
int sensorValue1 = 0; // Value Read From Input A0
int sensorValue2 = 0; // Value Read From Input A1
int sensorValue3 = 0; // Value Read From Input A2
int sensorValue4 = 0; // Value Read From Input A3
int sensorValue5 = 0; // Value Read From Input A4
int sensorValue6 = 0; // Value Read From Input A5
int setPoint = 300; // Initial value of setPoint
int R1State = 0; // Store State of Relay 1
int R2State = 0; // Store State of Relay 2
int R3State = 0; // Store State of Relay 3
int R4State = 0; // Store State of Relay 4
int R5State = 0; // Store State of Relay 5
int R6State = 0; // Store State of Relay 6
int R7State = 0; // Store State of Relay 7
int R8State = 0; // Store State of Relay 8
int R9State = 0; // Store State of Relay 9
int R10State = 0; // Store State of Relay 10
int R11State = 0; // Store State of Relay 11
int R12State = 0; // Store State of Relay 12
int voltage = 0;
// configure hardware
pinMode(R1, OUTPUT); // Set Relay 1 as an Output
pinMode(R2, OUTPUT); // Set Relay 2 as an Output
pinMode(R3, OUTPUT); // Set Relay 3 as an Output
pinMode(R4, OUTPUT); // Set Relay 4 as an Output
pinMode(R5, OUTPUT); // Set Relay 5 as an Output
pinMode(R6, OUTPUT); // Set Relay 6 as an Output
pinMode(R7, OUTPUT); // Set Relay 7 as an Output
pinMode(R8, OUTPUT); // Set Relay 8 as an Output
pinMode(R9, OUTPUT); // Set Relay 9 as an Output
pinMode(R10, OUTPUT); // Set Relay 10 as an Output
pinMode(R11, OUTPUT); // Set Relay 11 as an Output
pinMode(R12, OUTPUT); // Set Relay 12 as an Output
// read the analog in value
sensorValue1 = analogRead(analogInPin1);
voltage = sensorValue1 * 5.0/1023;
sensorValue2 = analogRead(analogInPin2);
sensorValue3 = analogRead(analogInPin3);
sensorValue4 = analogRead(analogInPin4);
sensorValue5 = analogRead(analogInPin5);
sensorValue6 = analogRead(analogInPin6);
// Check Voltage Level For Relays 1 & 2
if (sensorValue1 > setPoint)
R1State = 1;
R1State = 0;
R2State = 1;
R2State = 0;
// Check Voltage Level for Relays 3 & 4
if (sensorValue2 > setPoint)
R3State = 1;
R3State = 0;
R4State = 1;
R4State = 0;
// Check Voltage Levels for Relays 5 & 6
if (sensorValue3 > setPoint)
R5State = 1;
R5State = 0;
R6State = 1;
R6State = 0;
// Check Voltage Levels for Relays 7 & 8
if (sensorValue4 > setPoint)
R7State = 1;
R7State = 0;
R8State = 1;
R8State = 0;
// Check Voltage Levels for Relays 9 & 10 (SECONDARY)
if (sensorValue5 > setPoint)
R9State = 1;
R9State = 0;
R10State = 1;
R10State = 0;
// Check Voltage Levels for Relays 11 & 12 (SECONDARY)
if (sensorValue6 > setPoint)
R11State = 1;
R11State = 0;
R11State = 1;
R11State = 0;
// wait 100 milliseconds before the next loop
