Arduino Uno, shutdown output's problem. SOLVED
Hi, I need help concerning a problem that I have with my arduino Uno.
I’m using a ds18b20 temperature sensor:
And the OneWire library.
Code just below:
#include <OneWire.h>
int SensorPin = 13; //Our sensor is connected to digital pin 10
//Initiate OneWire communication
OneWire ds(SensorPin);
void setup(void) {
//Initiate serial communication with our computer
  digitalWrite(8,HIGH);
void loop(void) {
float T = readT(); // call function to read from sensor
Serial.print("Temperature is: "); // print out results to us
Serial.print(T);
Serial.println(" deg.C"); // print out results to us
delay(750);
float readT(){
//returns the temperature from our sensor
byte data[12];
byte addr[8];
if ( !ds.search(addr)) {
ds.reset_search();
return -300; // if there is no sensor on OneWire Bus, return -300 value
ds.reset();
ds.select(addr);
ds.write(0x44,1); // tell sensor to start converting
ds.reset();
ds.select(addr);
ds.write(0xBE); // tell sensor to start sending data
for (int i = 0; i < 9; i++) { // we receive data in this loop
data[i] = ds.read();
ds.reset_search();
byte MSB = data[1];
byte LSB = data[0];
float raw = ((MSB << 8) | LSB); // move MSB left for 8 spaces, join that with LSB
float realTempC = raw / 16; // move decimal point left for 4 spaces, result our temperature
return realTempC;
When I connect the vdd on the +5V or +3.3V arduino’s pin, there’s no problem, I can read the temperature, but when I connect it to a high level output arduino’s pin, this output pin start oscillating ( syncro with the data.)
I tried to put a 10uA capacitor between the vdd and the ground, but the vdd shuts to a 1.75V.
I’ve done current measures and in the worse case the circuit consumes 1mA, and arduino’s output maximum rate’s 40 mA.
Thanks for reading and any help will be appreciated.
but when I connect it to a high level output arduino's pin,/quote]
Its always best to comment your code lines. Show us how the circuit is wired.
digitalWrite(8,HIGH); did you make 8 an o/p or are you using this as i/p with pullups?
Problem SOLVED.
pin 8 was the VDD.
The problem was that I forgot to write:
pinMode(8, OUTPUT);
Thanks.
