Arduino uno shutting off when connecting A0 pin to 2 resistences
Everything works perfectly until I connect the analog 0 pin to the 2 resistences.
I have attached a picture of the tinkercad’s circuit and a bunch of pictures of the real circuit
I don’t know if that is caused by a short circuit or something else.
I’m a bit noob so i would like your help.
this is the code:
// Arduino Ohm meter, Misura resistenze
// Autore Fancello Salvatore
// Per maggiori info: www.progettiarduino.com
int analogPin= 0; // Pin Analogico A0
int raw= 0;
int Vin= 5; // Volt in uscita dal Pin 5V di Arduino
float Vout= 0;
float R1= 1000; // impostare il valore della resistenza nota in Ohm
float R2= 0;
float buffer= 0;
#include <LiquidCrystal.h>
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
lcd.begin(16, 2); //Inizializzazione display
Serial.begin(9600); //Apro la comunicazione seriale
raw= analogRead(analogPin);
if(raw)
buffer= raw * Vin;
Vout= (buffer)/1024.0;
buffer= (Vin/Vout) -1;
R2= R1 * buffer;
Serial.print("Vout: ");
Serial.println(Vout);
Serial.print("R2: ");
Serial.println(R2);
lcd.print(“OHM METER”);
lcd.setCursor(0, 1);
lcd.print("R2: ");
lcd.print(R2);
lcd.clear();
This is my arduino board:
https://www.amazon.com/Freenove-Processing-Oscilloscope-Voltmeter-Components/dp/B0721B8228
Thanks in advance.
I think you forgot the TinkerCad thing. I looked at all your pictures and they are all of your breadboard and I can't see anything under the mess of jumper wires.
