Arduino UNO sketch & push button
I found that the button state for pin 3 keep its original state when push. My intention here is after pin 2 button is push, it keeps waiting until the pin 3 button is being pushed.
int Auto=2;
int Manu=3;
int val1;
int val2;
int stateA;
int stateB;
  pinMode(Auto, INPUT);
  pinMode(Manu, INPUT);
  val1=digitalRead(Auto);
  val2=digitalRead(Manu);
  if (val1!=stateA)
    if (val1==HIGH)
      Serial.println("Auto");
      Serial.println("button auto released");
      if(val2==stateB)
        for(int i=0; i<10; i++){
          Serial.println(i);
          Serial.println("man:");
          Serial.println( val2);
          while(val2==HIGH)
            Serial.println("MAN");
        Serial.println("button man released");
  stateA=val1;
  stateB=val2;
No it doesn't.
So code it like that, that code does nothing like it.
Detect when pin 2 button is pressed, when it is set a flag ( variable )
Then when you see button 3 pressed and the flag is set - do what you want.
Some code to get you started
int state = 0;
const byte autoButtonPin = 2;
const byte manuButtonPin = 3;
  pinMode(autoButtonPin, INPUT_PULLUP);
  pinMode(manuButtonPin, INPUT_PULLUP);
  switch (state)
  case 0:
    if (digitalRead(autoButtonPin) == LOW)
      Serial.println("Auto button pressed.  Waiting for manual button to be pressed");
      state = 1;
  case 1:
    if (digitalRead(manuButtonPin) == LOW)
      Serial.println("Manual button has been pressed");
      state = 0;
