I'm hoping this is the correct area to post this question. If not, please tell me where this should be posted. Thank You in advance for any help.
I am attempting to build a unit to test and program a three color (R-G-B) LED board using SPI portion of an Arduino UNO R3. Basically, if a certain color button is depressed, the slave select (SS) lines goes low, then it sends the program to a DAC on the board. The trigger then turns on the appropriate color for ~2 seconds. None of my outputs are being triggered. I've watched every video (YouTube) and searched every board online for an answer. Can anyone point me at where I made my mistake? I'm not a programmer by any stretch of the term and freely admit this.
My code thus far;
#include<SPI.h> //SPI library
#include <InputDebounce.h> //debounce library
const int redButton = 1; //red switch
const int grnButton = 2; //green switch
const int bluButton = 3; //blue switch
const int slaveSelect = 10; //slave select
const int redTrigger = 5; //red trigger
const int grnTrigger = 6; //grn trigger
const int bluTrigger = 7; //blu trigger
#define RMP 0x13ff //red medium power
#define RFP 0x17ff //red full power
#define GMP 0x53ff //green medium power
#define GFP 0x57ff //green full power
#define BMP 0x93ff //blue medium power
#define BFP 0x97ff //blue full power
void setup ()
pinMode (redButton, INPUT);
pinMode (grnButton, INPUT);
pinMode (bluButton, INPUT);
pinMode (slaveSelect, OUTPUT);
pinMode (redTrigger, OUTPUT);
pinMode (grnTrigger, OUTPUT);
pinMode (bluTrigger, OUTPUT);
digitalWrite (redTrigger, HIGH); //red trigger set HI
digitalWrite (grnTrigger, HIGH); //grn trigger set HI
digitalWrite (bluTrigger, HIGH); //blu trigger set HI
digitalWrite (slaveSelect,HIGH); //turn off DAC programming
SPI.begin; //begin spi mode
void loop() //begin red read and program
if (redButton == HIGH); //begin red IF
digitalWrite (slaveSelect,LOW); //program DAC
SPI.transfer (RMP); //DAC red data
delay(10);
digitalWrite (slaveSelect,HIGH); //stop DAC programming
digitalWrite (5, LOW); //send red trigger
delay (2000);
digitalWrite (5, HIGH); //turn off red trigger
if (grnButton == LOW); //begin green IF
SPI.transfer (GMP); //DAC green data
delay(10);
digitalWrite (6, LOW); //send green trigger
delay (2000);
digitalWrite (6, HIGH); //turn off green trigger
if (bluButton == LOW); //begin blue IF
SPI.transfer (BMP); //DAC blue data
delay(10);
digitalWrite (7, LOW); //send blue trigger
delay (2000);
digitalWrite (7, HIGH); //turn off blue trigger
