Arduino uno spwm digitalread
Is it possible to use arduino uno to convert the spwm wave output by pin9 into digital signal with digitalread?
here is the code
#include <avr/io.h>
#include <avr/interrupt.h>
#define LookupEntries (512)
static int microMHz = 16;   // clock frequency in MHz
static int freq, amp = 1024;// Sinusoidal frequency
static long int period;     // Period of PWM in clock cycles. 1600 gives 10KHz.
static unsigned int lookUp[LookupEntries];
static char theTCCR1A = 0b10000010; //varible for TCCR1A
static unsigned long int phaseinc, switchFreq;
static double phaseincMult;
int setFreq(int freq);         //set in Hertz
int setSwitchFreq(int sfreq);  //set in Hertz
int setAmp(float _amp);        //set in % (0 - 100)
void makeLookUp(void);
void registerInit(void);
  pinMode (6, INPUT);
  makeLookUp();
  setSwitchFreq(10000);
  setFreq(50);
  setAmp(100);
  registerInit();
    The code in the loop reads analog values from pins A1 and A2 so that potentiometers can be connected.
    These values are used to vary the amplitude and frequency of the sine wave.
    The switching frequency also toggles between 5 and 15Khz.
  static int ampVal, freqVal, anologVal;
  int digitalValue = digitalRead(6);
  Serial.println(digitalValue);
  anologVal = analogRead(A0);
  if (anologVal > freqVal * 1.01 || anologVal < freqVal * 0.99) {
    freqVal = anologVal;
    setFreq(map(freqVal, 0, 1023, 5, 300));
  anologVal = analogRead(A1);
  if (anologVal > ampVal * 1.01 || anologVal < ampVal * 0.99) {
    ampVal = anologVal;
    setAmp(map(ampVal, 0, 1023, 0, 100));
  delay(20);
  static char cnt = 0;
  cnt++;
  if (cnt == 100) {
    setSwitchFreq(15000);
    cnt = 0;
  } else if (cnt == 50) {
    setSwitchFreq(5000);
ISR(TIMER1_OVF_vect) {
  static unsigned long int phase, lastphase;
  static char delay1, trig = LOW;
  phase += phaseinc;
  if (delay1 == 1) {
    theTCCR1A ^= 0b10100000;// Toggle connect and disconnect of compare output A and B.
    TCCR1A = theTCCR1A;
    delay1 = 0;
  else if ((phase >> 31 != lastphase >> 31) && !(phase >> 31)) {
    delay1++;
    trig = !trig;
    digitalWrite(13, trig);
  lastphase = phase;
  OCR1A = OCR1B = ((lookUp[phase >> 23] * period) >> 12) * amp >> 10;
int setFreq(int _freq) {
  if (_freq < 0 || _freq > 1000) { // returns -1 if the frequency value is invalid
    return 0;
    freq = _freq;
    phaseinc = (unsigned long int) phaseincMult * _freq;
    return 1;
int setSwitchFreq(int sfreq) {
  double temp;
  if (sfreq <= 0 || sfreq > 20000) {
    return 0;
    switchFreq = sfreq;
    period = microMHz * 1e6 / sfreq;
    //sindevisions*decimalbits/1MHz =
    //1024*2^23/1e6 = 8,589.934592
    phaseincMult = (double) period * 8589.934592 / microMHz;
    phaseinc = (unsigned long int) phaseincMult * freq;
    ICR1   = period;
  if (_amp < 0 || _amp > 100) {
    return 0;
    amp = map(_amp, 0, 100, 0, 1024);
    return 1;
void makeLookUp(void) {
  double temp;
  cli(); //disable global interupts while lookup table is made
  TCCR1A = 0b00000010; //disconnect compare A and B while lookup table is generated
  for (int i = 0; i < LookupEntries; i++) { // Generating the look up table.
    temp = sin(i * M_PI / LookupEntries) * 4096;
    lookUp[i] = (int)(temp + 0.5);     // Round to integer.
  TCCR1A = theTCCR1A; // reconnect compare outputs
  sei(); //re-enable interupts now that table has been made
void registerInit(void) {
  // Register initilisation, see datasheet for more detail.
  TCCR1A = theTCCR1A; // 0b10000010;
  /*10 clear on match, set at BOTTOM for compA.
    00 compB disconected initially, toggled later to clear on match, set at BOTTOM.
    00
    10 WGM1 1:0 for waveform 15.
  TCCR1B = 0b00011001;
  /*000
    11 WGM1 3:2 for waveform 15.
    001 no prescale on the counter.
  TIMSK1 = 0b00000001;
  /*0000000
    1 TOV1 Flag interrupt enable.
  sei();             // Enable global interrupts.
  // Set outputs pins.
  DDRB   = 0b00000110; // Set PB1 and PB2 as outputs.
  pinMode(13, OUTPUT); // Set trigger pin to output
The value read is not the expected spwm
Hello yian1129
Take some time and describe the desired function of the sketch in simple words and this very simple.
PWM of any type is a ‘square’ wave, so we need to understand your requirement a bit better.
I think your requirement can be done fairly simply, but as above, the problem needs to be explained a bit more clearly.
What’s your base PWM frequency, are you spanning the full 0-100% Pwm range ?
QPOS2129
My square wave is 10kHz switching frequency spwm wave (green)
yes!!!
Didn´t you read and understood post #2, did you?
i'm sorry. i'm trying to understand.
You may use an online translator app?
Sorry sir,did you mean I should explain the code part first right?
yes... My english is not very good.
Not the code, explain what you want to do with it.
I try to use NRF24L01 wireless transmission module to transmit SPWM
So I have to convert SPWM into digital form first so that the wireless transmission module can read the data.
HI,
Does the input signal change in frequency and/or duty cycle?
Thanks.. Tom... :smiley: :+1: :coffee: :australia:
yes,the duty cycle change every period,and frequency can be changed.
I think you’re chasing the wrong postman.
Send yiur ‘parameters’ over the RF link, then program the receiving radio to regenerate the PWM
