ARDUINO UNO + STEPPERMOTOR +DRIVER + DISPLAY
MY PROJECT IS TO HAVE A STEPPER MOTOR CONTROL FROM ARDUINO USING MICROSTEP DRIVER AND A POTENTIOMETER TO VARIE THE SPEED WHICH IS DISPLAYED ON AN LCD DISPLAY .
The problem is that when I control the stepper motor without display the motor works perfectly but when introduce the display " the refesh rate of the display " is effecting the speed and performance of the motor.
Is there any way how to tackel this problem?
Thanks
Post a schematic. Post your code according to the forum guidelines (that you apparently did not bother to read).
Please do not shout at us.
PADDYMALTA:
Not unless you are prepared to post your program.
...R
The "how to use this forum" postings are there to prevent this sort of Q&A session - post all the details, circuit, code, datasheet links etc, up front - we can't guess these details and details always matter.
Hi ALL --
This is my Code - :slight_smile:
//---------------LCD --------------------------
#include <Wire.h>
#include <LiquidCrystal_PCF8574.h>
LiquidCrystal_PCF8574 lcd(0x27);
#define ok 8
#define up 9
#define down 10
int count = 0;
int PBdelay = 200;
int state = 0;
int stateA = 0;
int push =0;
int qty =0;
int len = 0;
int countA = 0;
int countB = 0;
int i = 0;
//------------- STEPPER ------------------
const int analogInPin = A0; // Analog input pin that the potentiometer is attached to
const int analogOutPin = 13; // Analog output pin that the LED is attached to
int sensorValue = 0; // value read from the pot
int outputValue = 0; // value output to the PWM (analog out)
int PUL = 7; //define Pulse pin
int DIR = 6; //define Direction pin
int ENA = 5; //define Enable Pin
pinMode (PUL, OUTPUT);
pinMode (DIR, OUTPUT);
pinMode (ENA, OUTPUT);
// Serial.begin(9600);
//------------LCD -------------------
lcd.begin(16, 2); // initialize the lcd
digitalWrite(ENA, LOW); // not to let the Stepper Energised when not
//Serial.println(value_potentiometer);
// read the analog in value:
sensorValue = analogRead(analogInPin);
// Serial.println( sensorValue);
// map it to the range of the analog out:
outputValue = map(sensorValue, 0, 1023, 0, 500);
// Serial.println(outputValue);
// change the analog out value:
// analogWrite(analogOutPin, outputValue);
digitalWrite(DIR, LOW);
digitalWrite(ENA, HIGH);
digitalWrite(PUL, HIGH);
delayMicroseconds (outputValue);
digitalWrite(PUL, LOW);
delayMicroseconds(outputValue);
// wait 2 milliseconds before the next loop for the analog-to-digital
// converter to settle after the last reading:
delay(1);
//Serial.println(outputValue);
//--------lcd-------------------
lcd.setBacklight(255);
lcd.home(); lcd.clear();
lcd.print(outputValue);
// lcd.clear();
// delay(1000);
// lcd.setCursor(1,2);
// lcd.cursor();
// delay(1000);
PADDYMALTA:
Hi ALL --
This is my Code
This is the culprit I'm sure:
   delay(1000); // <<<<<<<<<<<<<<<<<<<<<<
You'll have to do your update delay()-lessly. Have a look at blink without delay, but intead of toggling a led, write the lcd.
IT worked . Thanks alot :slight_smile: :slight_smile:
Is that Mini in your pic of your namesake Paddy Hopkirk?
12Stepper:
YES mini wwwwooooommmmmmmm ............ :slight_smile:
12Stepper:
You'll have to do your update delay()-lessly. Have a look at [blink without delay](https://www.arduino.cc/en/Tutorial/BlinkWithoutDelay), but intead of toggling a led, write the lcd.
12Stepper, Im noticing that when the display refresh there is a slightly bit of change in the motor performance.. You can listen to it changing a bit due to refresh of display.. It is not as it was with the delay function .... How could I solve it ? should I use 2 arduinos one to control the Stepper and another one for the display ?
THanks alot
This is the code ---
#include <Wire.h>
#define ok 8
#define up 9
#define down 10
int count = 0;
int PBdelay = 200;
int state = 0;
int stateA = 0;
int push =0;
int qty =0;
int len = 0;
int countA = 0;
int countB = 0;
int i = 0;
unsigned long previousMillis = 0;        //
const long interval = 1000;           //
int DISPLAYrefreshstate = LOW;             //
  outputValue = map(sensorValue, 0, 1023, 140, 1000);
  delayMicroseconds(10);
  if (currentMillis - previousMillis >= interval) {
    if (DISPLAYrefreshstate == LOW) {
      DISPLAYrefreshstate = HIGH;
    // set the LED with the ledState of the variable:
 //  delay(1000);
 //  lcd.clear();
//    delay(1000);
  //lcd.setCursor(1,2);
 //  lcd.cursor();
 //   delay(1000);
PADDYMALTA:
To make it easy for people to help you please modify your post and use the code button </>
so your code
looks like this
and is easy to copy to a text editor. See How to use the Forum
...R
Robin2:
so your code
looks like this
and is easy to copy to a text editor. See [How to use the Forum](http://forum.arduino.cc/index.php?topic=149014.0)
...R
Thanks
Thanks for fixing up the code, but by now I'm afraid I have forgotten the question.
...R
