Everything was working fine. I was making changes to my sketch and uploading. Then at one point when I tried opening the serial monitor my mac went into reboot thereafter I could not upload a sketch.
When I was uploading the arduino was powered by an external 12v source.
What could have gone wrong? Is the board toast?
Here is the error message:
Arduino: 1.8.10 (Mac OS X), Board: "Arduino/Genuino Uno"
Sketch uses 444 bytes (1%) of program storage space. Maximum is 32256 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2039 bytes for local variables. Maximum is 2048 bytes.
/Applications/Arduino 5.app/Contents/Java/hardware/tools/avr/bin/avrdude -C/Applications/Arduino 5.app/Contents/Java/hardware/tools/avr/etc/avrdude.conf -v -patmega328p -carduino -P/dev/cu.wchusbserialfd120 -b115200 -D -Uflash:w:/var/folders/xz/1x9v0skx3tz6wrfvzgy1b4gr0000gn/T/arduino_build_544492/sketch_dec03c.ino.hex:i
avrdude: Version 6.3-20190619
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "/Applications/Arduino 5.app/Contents/Java/hardware/tools/avr/etc/avrdude.conf"
User configuration file is "/Users/johndoe/.avrduderc"
User configuration file does not exist or is not a regular file, skipping
Using Port : /dev/cu.wchusbserialfd120
Using Programmer : arduino
Overriding Baud Rate : 115200
avrdude: ser_open(): can't open device "/dev/cu.wchusbserialfd120": No such file or directory
avrdude done. Thank you.
Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
option enabled in File -> Preferences.
