I'm trying to communicate between a Arduino Uno and several ATtiny85's with I2C.
On the internet I only can find examples of sending data from the Uno to the tiny and the ATtiny is responding to this info by lightning some LED's or switching some Relais. This is communicating in one direction.
I want to sent data from the Uno to the Tiny. The Tiny has to answer depending on this data.
For example, every ATtiny85, in the circuit, is measuring a value.
Then the Arduino Uno asks to give the result of this measurement, every hour, to every ATtiny on the I2C-line. So the Uno is asking for results.
Where can I find some info about communication between an Arduino Uno and an ATtiny85 via I2C?
I added some extra lines in a few "TinyWireS-files" and it works fine.
I do not understand why these lines are missing in the original files and what these lines do.
But I don't care, I can communicate between my ArduinoUno and my ATtiny's.
The forum is useless unless people share their work, good or bad. Not a good idea to critique other peoples work and time without detailed explanation of what's at fault. Don't be so selfish; show us what you've done so others can learn from your experience.
Oh sorry, I didn't mean to critique other people.
I thanked you for your help.
What I did, to solve my problem, is adding some extra lines in some TinyWireS-library-files. As explained on the websides you mentioned.
I only followed your instructions. No more no less.
So again thanks.
Glad to help, but you still haven't shared what lines you added.
Your actions imply that others may need to add the same lines to the library code. That's not helpful to others, and not in the spirit of a forum. On the links, there were examples using Wire.h with Arduino platforms; so what did you add to TinyWireS.h to make it like Wire.h?
