Hi to all.
I have connected an Arduino UNO, one TCA9548A multiplexer and two ADXL345 accelerometers (manufactured by Sunkee). I have attached my wiring layout. I am trying to run the code you have shared as an example under the TCA9548A heading. The only change I made on this code was the serial monitor’s data transfer speed because I was getting gibberish “Serial.Begin(9600)”. My two ADXL345 accelerometers are not being recognized at all.
I used/tested a second TCA9548A multiplexer with the same results, no device was detected.
I used Adafruit’s code at https://learn.adafruit.com/adxl345-digi … rogramming. I tried to run just one directly accelerometer directly from the Arduino. I run their “sensortest” code and the output was as expected (pasted below).
I would like to mention that the two Sunkee ADXL345 accelerometers have a static address, 0x53. The protocol I’m using to read them is I2C.
Can someone please help me?
Thank you,
Accelerometer Test.
Sensor: ADXL345
Driver Ver: 1
Unique ID: 12345
Max Value: -156.91 m/s^2
Min Value: 156.91 m/s^2
Resolution: 0.04 m/s^2
Data Rate: 100 Hz
Range: +/- 16 g
X: 0.31 Y: 0.78 Z: 9.53 m/s^2
X: 0.31 Y: 0.82 Z: 9.57 m/s^2
X: 0.31 Y: 0.78 Z: 9.65 m/s^2
X: 0.27 Y: 0.78 Z: 9.61 m/s^2
X: 0.31 Y: 0.78 Z: 9.61 m/s^2
X: 0.31 Y: 0.78 Z: 9.57 m/s^2
