Arduino Uno + Telefonica GSM Shield + Interrupt (PinChangeInt ?)
Hi, I’m working on a project where I’m using an Arduino UNO + Telefonica GSM shield and need to use at least one interrupt but since the GSM shield uses Pin2 & 3 there is no interrupt left for me to use.
It seems PinChangeInt library is the solution but I´m not able to figure out how to use it.
Adding both libraries as follows
//GSM VARIABLES
// libraries
#include <GSM.h>
#include <PinChangeInt.h>
generates the following compile errors
GSM/GSM3SoftSerial.cpp.o: In function __vector_5': /Applications/Arduino.app/Contents/Resources/Java/libraries/GSM/src/GSM3SoftSerial.cpp:525: multiple definition of __vector_5’
W2S_GSM_V1.cpp.o:/Applications/Arduino.app/Contents/Resources/Java/libraries/PinChangeInt/PinChangeInt.h:585: first defined here
GSM/GSM3SoftSerial.cpp.o: In function __vector_4': /Applications/Arduino.app/Contents/Resources/Java/libraries/GSM/src/GSM3SoftSerial.cpp:518: multiple definition of __vector_4’
W2S_GSM_V1.cpp.o:/Applications/Arduino.app/Contents/Resources/Java/libraries/PinChangeInt/PinChangeInt.h:575: first defined here
GSM/GSM3SoftSerial.cpp.o: In function __vector_3': /Applications/Arduino.app/Contents/Resources/Java/libraries/GSM/src/GSM3SoftSerial.cpp:511: multiple definition of __vector_3’
W2S_GSM_V1.cpp.o:/Applications/Arduino.app/Contents/Resources/Java/libraries/PinChangeInt/PinChangeInt.h:565: first defined here
What am I doing wrong?
Many thanks in advance
I’m new to the subject, I recently bought a Arduino GSM Shield, I’m doing the arduino examples provided. I made the code as it is written like this there. and when I try to type the phone number for the serial port does nothing more, I need your help to see if there is an error in the code. Thank you.
link: http://arduino.cc/en/Reference/GSMSMSEndSMS?action=sourceblock&num=1
#include <GSM.h>
#define PINNUMBER “”
// initialize the library instance
GSM gsmAccess; // include a ‘true’ parameter for debug enabled
GSM_SMS sms;
// initialize serial communications
Serial.println(“SMS Messages Sender”);
// connection state
boolean notConnected = true;
// Start GSM shield
// If your SIM has PIN, pass it as a parameter of begin() in quotes
while(notConnected)
if(gsmAccess.begin(PINNUMBER)==GSM_READY)
notConnected = false;
Serial.println(“Not connected”);
Serial.println(“GSM initialized”);
Serial.print("Enter a mobile number: ");
char remoteNumber[20]; // telephone number to send sms
readSerial(remoteNumber);
Serial.println(remoteNumber);
// sms text
Serial.print("Now, enter SMS content: ");
char txtMsg[200];
readSerial(txtMsg);
Serial.println(“SENDING”);
Serial.println(“Message:”);
Serial.println(txtMsg);
// send the message
sms.beginSMS(remoteNumber);
sms.print(txtMsg);
sms.endSMS();
Serial.println("\nCOMPLETE!\n");
Read input serial
int readSerial(char result)
int i = 0;
while(1)
while (Serial.available() > 0)
char inChar = Serial.read();
if (inChar == ‘\n’)
result = ‘\0’;
Serial.flush();
return 0;
if(inChar!=’\r’)
result = inChar;
i++;
Nothing seems to be wrong with your code, as it is exactly the same provided by the SendSMS example .
Two questions: 1 - In which Arduino board are you loading it? 2 -Do you get any message at all on the Serial Monitor?
Best!
