Arduino Uno time running slow
I have an Arduino Uno with a LCD connected by I2C. I realized when I am writing messages to it it does not show the correct time, it's ~50% off. I tried to print the millis() only, which is off by the same amount.
I found an old thread where it was caused by the delayMicroseconds() in the LiquidCrystal.cpp, so I tried those fixes, aswell as commenting out the LCD-update code, which no difference (I sent the millis() over the serial this time).
Does anyone know what could be causing the timer to be slow on this Arduino?
#include <Wire.h>
#include <SoftwareSerial.h>
#include "CustomChars.h"
#define TX_BAUD 2400
#define PACKET_SIZE 3
#define DELAY 50
#define RX_PIN 2
#define TX_PIN 3
#define LCD_UPDATE 490
// Set the LCD address to 0x27 for a 16 chars and 2 line display
LiquidCrystal_I2C lcd(0x27, 16, 2);
SoftwareSerial telemetry(RX_PIN,TX_PIN);
byte packet[PACKET_SIZE];
byte voltage[2];
unsigned long lastUpdate = 0;
unsigned long receivedPackets = 0;
unsigned long lastPacks = 0;
int packetsPerSecond = 0;
  telemetry.begin(TX_BAUD);
  lcd.begin();
  lcd.createChar(0,antenna);
  lcd.createChar(1,oneBar);
  lcd.createChar(2,twoBars);
  lcd.createChar(3,threeBars);
  lcd.createChar(4,fourBars);
  lcd.createChar(5,fiveBars);
  lcd.createChar(6,noBars);
  lcd.backlight();
  lcd.clear();
  lcd.home();
  lcd.print("Naze32 Telemetry");
  lcd.clear();
  while(telemetry.available() > 0){
    addByte(telemetry.read());
    if (testChecksum(packet, PACKET_SIZE)){
      voltage[0] = packet[0];
      voltage[1] = packet[1];
      receivedPackets++;
  if (millis() - lastUpdate > LCD_UPDATE){
    updatePacketsPerSecond();
    lastUpdate = millis();
    lcd_WriteVoltage();
    lcd_WriteTime();
    //lcd_WriteMillis();
    lcd_WriteConnectionStatus();
    lcd_WriteConnected();
void addByte(byte b){
  for (byte i = 0; i < PACKET_SIZE-1; i++){
    packet[i] = packet[i+1];
  packet[PACKET_SIZE-1] = b;
bool testChecksum(byte* packet, byte packetSize){
  byte crc = CRC8(packet, PACKET_SIZE-1);
  return (packet[PACKET_SIZE-1] == crc);
byte CRC8(const byte *data, byte len){
  byte crc = 0x00;
  while (len--) {
    byte extract = *data++;
    for (byte tempI = 8; tempI; tempI--) {
      byte sum = (crc ^ extract) & 0x01;
      crc >>= 1;
      if (sum) {
        crc ^= 0x8C;
      extract >>= 1;
  return crc;
void updatePacketsPerSecond(){
  packetsPerSecond = 1000*(receivedPackets - lastPacks)/(millis()-lastUpdate);
  lastPacks = receivedPackets;
void lcd_WriteVoltage(){
  char string[8];
  sprintf(string,"%02u.%uV",voltage[0],voltage[1]);
  for (byte i = 0; i < 8; i++){
    if (string[i] == 'V'){
      for (byte b = i+1; b < 8; b++){
        string[b] = ' ';
  lcd.setCursor(0,0);
  lcd.print(string);
void lcd_WriteConnectionStatus(){
  lcd.setCursor(0,1);
  char string[6];
  sprintf(string,"%03ipps",packetsPerSecond);
  lcd.print(string);
void lcd_WriteTime(){
  char time[8];
  getTime(time);
  lcd.setCursor(9,0);
  lcd.print(time);
void getTime(char *time){
  unsigned long t = millis()/1000;
  byte h = t/3600;
  byte m = (t-h*3600)/60;
  byte s = t-60*(60*h+m);
  sprintf(time,"%u:%02u:%02u",h,m,s);
void lcd_WriteConnected(){
  if (isConnected()){
    lcd.setCursor(7,1);
    lcd.write(0);
    if (packetsPerSecond > 99)
      lcd.write(5);
    else if (packetsPerSecond > 89)
     lcd.write(4);
    else if (packetsPerSecond > 69)
     lcd.write(3);
    else if (packetsPerSecond > 49)
     lcd.write(2);
     lcd.write(1);
  else {
    lcd.setCursor(7,1);
    lcd.write(0);
    lcd.write(6);
bool isConnected(){
  return packetsPerSecond > 30;
void lcd_WriteMillis(){
  lcd.setCursor(0,0);
  lcd.print(millis() / 1000);
