Arduino UNO to breadboard
I'm using the tutorial from Arduino forum website to code an ATmega328 (to basically make my own Arduino on breadboard)
However the chip wont code. I've selected "Arduino uno/ geniuno board and AVRISP mkll
What have I done wrong, here are my error codes.
[Arduino: 1.8.5 (Windows 10), Board: "Arduino/Genuino Uno"
Sketch uses 1574 bytes (4%) of program storage space. Maximum is 32256 bytes.
Global variables use 10 bytes (0%) of dynamic memory, leaving 2038 bytes for local variables. Maximum is 2048 bytes.
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xc1
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0xc1
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0xc1
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0xc1
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0xc1
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0xc1
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0xc1
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0xc1
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0xc1
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0xc1
Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
option enabled in File -> Preferences.
Kind Regards
When are you getting this error? Have you already successfully gotten through the "Burning the Bootloader" step of the tutorial?
I haven’t burnt the boot loader because I took the ATmega328 directly out of the Arduino UNO board.
I’ve successfully downloaded code onto the ATmega328 using the tutorial link above before however when I plugged my ATmega328 into my strip board along with my components and ceramic capacitors and crystal, it didn’t work so I need some help.
