Hi..
i am stuck with uart and would be grateful if i got some help from the experts.
i am reading 2 sensor values, sensor 1 and sensor 2. they both have values from 0 till 500, no decimal. and i want to send these 2 values over uart to an avr microcontroller (Atmega32).
i have been reading all over the forums, and i guess i need to use stdin, stdout, printf and scanf.
the output from arduino is like that:
324,123;432,212;442,112;
data will flow for like one min then stop, after 5 minutes it should flow again.
FILE uart_str = FDEV_SETUP_STREAM(uart_putchar, uart_getchar, _FDEV_SETUP_RW);
stdout = stdin = stderr = &uart_str;
do you guys agree? or is there any other way to do that?
thanks
Can you post a link to specs/data of the sensors please?
Thanks.. Tom...
Hey Tom, thanks for replying, here the code
#define LCS_413 0x44 //default Adresse
#include <Wire.h>
Wire.begin();
delay(100);
if(Serial.available()==0)
Serial.print(SENSOR1());
Serial.print(",");
Serial.print(SENSOR2());
// UART code to send sensor values
uint8_t XXX_888_readingReg(uint8_t reg)
uint8_t x ;
Wire.beginTransmission(LCS_413);
Wire.write((byte)reg);
Wire.endTransmission(false);
Wire.requestFrom((byte)LCS_413, (byte)1);
x = Wire.read();
return x;
long SENSOR1()
int z=XXX_888_readingReg(0x22);
int t=XXX_888_readingReg(0x15);
t=t>>4;
long n =z<<4;
n+=t;
return n;
long SENSOR2()
int r=XXX_888_readingReg(0x24);
int e=XXX_888_readingReg(0x15);
e=e&0x0F;
long m =r<<4;
m+=e;
return m;
