Arduino Uno upload error stk
Arduino: 1.8.13 (Windows 7), Board: "Arduino Uno"
Sketch uses 1488 bytes (4%) of program storage space. Maximum is 32256 bytes.
Global variables use 188 bytes (9%) of dynamic memory, leaving 1860 bytes for local variables. Maximum is 2048 bytes.
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x00
An error occurred while uploading the sketch
option enabled in File -> Preferences.
@sritej
Correct port selected?
@sritej
TOPIC SPLIT
DO NOT HIJACK / NECRO POST !
Could you take a few moments to Learn How To Use The Forum.
Other general help and troubleshooting advice can be found here.
could you post the whole error code
Please provide more information, are you not able to see the ports under IDE-> Tools> Ports?
  • Describe the behavior of L Led on pressing Reset Button. (It must Blink twice very fast).
  • Go to: Arduino IDE > File > Preferences > Show verbose output: Select both options: "Compilation" and "Upload". Then try to upload the Blink example (Arduino IDE > Files > Examples > Basics > Blink) and please send to us the copy of the whole text shown in the console.
  • Connect the board to a different computer and check if it has the same behavior.
Ensure nothing connected to pins 0 or 1. These are used for the upload process and things connected to them will interfere.
Also if you do see the triple blink when you press reset, if you open serial monitor, do you also see the triple blink? If not, autoreset is not working.
If no triple blink at all, bootloader not present or chip damaged.
