Arduino UNO upload problem
I have a small problem: it's been several months since I had not used my Arduino and now during the upload, it shows me the error.
avrdude: Version 6.3-20171130
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "/Applications/Arduino.app/Contents/Java/hardware/tools/avr/etc/avrdude.conf"
User configuration file is "/Users/**********/.avrduderc"
User configuration file does not exist or is not a regular file, skipping
Using Port : /dev/cu.usbmodem14221
Using Programmer : arduino
Overriding Baud Rate : 115200
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x00
avrdude done. Thank you.
Problème de téléversement vers la carte. Voir http://www.arduino.cc/en/Guide/Troubleshooting#upload pour suggestions.
I have tried everything. Reset during upload, etc., but still show the error.
I do not understand. In addition, the LED "L" remains lit permanently, perhaps a program that runs continuously?
In addition, I can not even burn the bootloader, boot sequence so I have no way.
Do I have to buy a new Arduino completely?
-- INFORMATIONS SYSTEME --
OS: Mac OSX El Capitan 10.11.6 (J'ai testé sur un autre mac doté de la même version) sur MacBook Pro Retina de fin-2012 (j'ai testé sur l'autre mac qui est lui un MacBook Pro de mi-2009)
-- INFORMATIONS ARDUINO --
Version Arduino IDE: Dernière (1.8.6, téléchargée aujourd'hui (27/08/18).
Carte: Elegoo Arduino Uno R3 (équivalent à Arduino UNO R3)
Programmeur: (aucun)
Code du logiciel: Blanc (void setup{}; void loop {})
[X] Câble d'origine du kit acheté
[X] Arduino n'étant branché à rien
Thank you in advance!
So, did you?
You are using the latest release of the IDE. Sometimes the error you are receiving is an indication of a bad installation. Can you try an older version? Try reinstalling the IDE.
