arduino UNO using I2C bus boot time
Hello,
I successfully design a software using the I2C bus.
This software don't use the serial port, just one wire bus, SPI and GPIOs.
Device are powered by a relay, I have to know the boot up time.
I just need to know the boot time before I can send and request data on the bus with a margin.
Best regards.
Thierry
Depends on the code you wrote...
If you want to measure, just set a pin high when you're done setting up everything and measure the time between power on and that pin going high. Easiest with a 2 (or more) channel scope.
Or just use a arbitrary time based on trail and error...
Hello,
The arduino uno is connecting in the I2C bus as a client.
The setup fuction is very short.
I have to need the time the master in the I2C bus have to wait before sending the first data....
I can wait but the delay should be suffisiant in all case.
Many thanks in advance.
Best regards.
Thierry
One thing you can do, is include code to send a client status response message in response to a poll from the master. Then when you initialize the master, have it poll the client for a ready status.
Then you don't have to measure the startup time or estimate a safety margin.
Hello,
Yes it's a great idea !
I can do it easly !
Thanks for the idea !
Best regards
Thierry
