Arduino UNO Voltmeter + nrf24l01
My first post, please bare with me.
So i have 2 arduino uno r3 boards with voltmeter codes, the voltmeter codes are working perfectly
here is the code:
int analogInput = 0;
float vout = 0.0;
float v1 = 0.0;
float v2 = 0.0;
float vave = 0.0;
float vdif = 0.0;
float vsum = 0.0;
float R1 = 102000.0;
float R2 = 9800.0; //Voltage divider is used for the arduino to read up to 30V
int value = 0;
void setup(){
   pinMode(analogInput, INPUT);
   Serial.begin (9600);
void loop(){
   value = analogRead(analogInput);
   vout = (value * 5.0) / 1023.0; //Formula for the Voltage of the Analog
   v1 = vout / (R2/(R1+R2));
   vave = (v1+v2)/2.0;
   vdif = v1-v2;
   vsum = v1+v2;
   Serial.print ("V1=");
   Serial.print (v1);
   Serial.print ("     ");
   Serial.print ("V2=");
   Serial.print (v2);
   Serial.println ("");
   Serial.print ("Vdiff=");
   Serial.print (vdif);
   Serial.print ("     ");
   Serial.print ("Vave=");
   Serial.print (vave);
what i want to do is that the voltage that is read on the 1st Arduino or V1 is then transmitted to my 2nd Arduino with another Voltage V2. The 2nd Arduino will act as a receiver and Add V1 and V2.
I have read a lot of codes regarding data transfer using nrf24l01 and i have to say im stuck. can anyone point me in the right direction on how to send the “voltage values” and what should i do. Ty
If you look at the examples for Maniacbug's RF24 library you'll find examples that show how to send and receive a simple message between two units. In your case the message you're sending would be the voltage value(s) you want to transfer.
On one side you would have code to read the input(s) and calculate the corresponding voltage(s) and then use code similar to the Maniacbug transmitter examples to transmit them.
On the receiving side you would have code based on the Maniacbug receiver examples to receive the message, extract the voltage(s) and then do whatever it is you want to do with the voltages.
Yes, thats it im actually looking at https://github.com/stanleyseow/RF24/tree/master/examples/nRF24_Serial_Chat i believe that this is the codes you are referring to? if not are you referring to this code?
 Copyright (C) 2011 J. Coliz <maniacbug@ymail.com>
 This program is free software; you can redistribute it and/or
 modify it under the terms of the GNU General Public License
 version 2 as published by the Free Software Foundation.
 * Example using Dynamic Payloads
 * This is an example of how to use payloads of a varying (dynamic) size.
#include <SPI.h>
#include "nRF24L01.h"
#include "RF24.h"
#include "printf.h"
// Hardware configuration
// Set up nRF24L01 radio on SPI bus plus pins 9 & 10
RF24 radio(9,10);
// sets the role of this unit in hardware.  Connect to GND to be the 'pong' receiver
// Leave open to be the 'ping' transmitter
const int role_pin = 7;
// Topology
// Radio pipe addresses for the 2 nodes to communicate.
const uint64_t pipes[2] = { 0xF0F0F0F0E1LL, 0xF0F0F0F0D2LL };
// Role management
// Set up role.  This sketch uses the same software for all the nodes
// in this system.  Doing so greatly simplifies testing.  The hardware itself specifies
// which node it is.
// This is done through the role_pin
// The various roles supported by this sketch
typedef enum { role_ping_out = 1, role_pong_back } role_e;
// The debug-friendly names of those roles
const char* role_friendly_name[] = { "invalid", "Ping out", "Pong back"};
// The role of the current running sketch
role_e role;
// Payload
const int min_payload_size = 4;
const int max_payload_size = 32;
const int payload_size_increments_by = 2;
int next_payload_size = min_payload_size;
char receive_payload[max_payload_size+1]; // +1 to allow room for a terminating NULL char
void setup(void)
  // Role
  // set up the role pin
  pinMode(role_pin, INPUT);
  digitalWrite(role_pin,HIGH);
  delay(20); // Just to get a solid reading on the role pin
  // read the address pin, establish our role
  if ( digitalRead(role_pin) )
    role = role_ping_out;
    role = role_pong_back;
  // Print preamble
  Serial.begin(57600);
  printf_begin();
  printf("\n\rRF24/examples/pingpair_dyn/\n\r");
  printf("ROLE: %s\n\r",role_friendly_name[role]);
  // Setup and configure rf radio
  radio.begin();
  // enable dynamic payloads
  radio.enableDynamicPayloads();
  // optionally, increase the delay between retries & # of retries
  radio.setRetries(15,15);
  // Open pipes to other nodes for communication
  // This simple sketch opens two pipes for these two nodes to communicate
  // back and forth.
  // Open 'our' pipe for writing
  // Open the 'other' pipe for reading, in position #1 (we can have up to 5 pipes open for reading)
  if ( role == role_ping_out )
    radio.openWritingPipe(pipes[0]);
    radio.openReadingPipe(1,pipes[1]);
    radio.openWritingPipe(pipes[1]);
    radio.openReadingPipe(1,pipes[0]);
  // Start listening
  radio.startListening();
  // Dump the configuration of the rf unit for debugging
  radio.printDetails();
void loop(void)
  // Ping out role.  Repeatedly send the current time
  if (role == role_ping_out)
    // The payload will always be the same, what will change is how much of it we send.
    static char send_payload[] = "ABCDEFGHIJKLMNOPQRSTUVWXYZ789012";
    // First, stop listening so we can talk.
    radio.stopListening();
    // Take the time, and send it.  This will block until complete
    printf("Now sending length %i...",next_payload_size);
    radio.write( send_payload, next_payload_size );
    // Now, continue listening
    // Wait here until we get a response, or timeout
    unsigned long started_waiting_at = millis();
    bool timeout = false;
    while ( ! radio.available() && ! timeout )
      if (millis() - started_waiting_at > 500 )
        timeout = true;
    // Describe the results
    if ( timeout )
      printf("Failed, response timed out.\n\r");
      // Grab the response, compare, and send to debugging spew
      uint8_t len = radio.getDynamicPayloadSize();
      radio.read( receive_payload, len );
      // Put a zero at the end for easy printing
      receive_payload[len] = 0;
      // Spew it
      printf("Got response size=%i value=%s\n\r",len,receive_payload);
    // Update size for next time.
    next_payload_size += payload_size_increments_by;
    if ( next_payload_size > max_payload_size )
    // Try again 1s later
  // Pong back role.  Receive each packet, dump it out, and send it back
  if ( role == role_pong_back )
    // if there is data ready
    if ( radio.available() )
      // Dump the payloads until we've gotten everything
      uint8_t len;
      bool done = false;
      while (!done)
        // Fetch the payload, and see if this was the last one.
	done = radio.read( receive_payload, len );
	// Spew it
	printf("Got payload size=%i value=%s\n\r",len,receive_payload);
      // Send the final one back.
      radio.write( receive_payload, len );
      printf("Sent response.\n\r");
      // Now, resume listening so we catch the next packets.
// vim:cin:ai:sts=2 sw=2 ft=cpp
