Arduino Uno + W5100
Hello.
I'm use the sabj. I need the RS-232<->Ethernet converter.
My code is summary examples Ethernet Telnet & SoftwareSerial:
 The circuit:
 * RX is digital pin 3 (connect to TX of other device)
 * TX is digital pin 5 (connect to RX of other device)
#include <SoftwareSerial.h>
#include <SPI.h>
#include <Ethernet.h>
SoftwareSerial mySerial(3, 5); // RX, TX
// Enter a MAC address and IP address for your controller below.
// The IP address will be dependent on your local network.
// gateway and subnet are optional:
byte mac[] = {
  0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED
IPAddress ip(192, 168, 1, 177);
IPAddress myDns(192,168,1, 1);
IPAddress gateway(192, 168, 1, 1);
IPAddress subnet(255, 255, 0, 0);
// telnet  to port 509
EthernetServer server(509);
boolean alreadyConnected = false; // whether or not the client was connected previously
  // initialize the ethernet device
  Ethernet.begin(mac, ip, myDns, gateway, subnet);
  // start listening for clients
  server.begin();
  while (!Serial) {
    ; // wait for serial port to connect. Needed for native USB port only
  Serial.print("Chat server address:");
  Serial.println(Ethernet.localIP());
   // set the data rate for the SoftwareSerial port
  mySerial.begin(9600);
  mySerial.println("Hello, world?");
  // wait for a new client:
  // when the client sends the first byte, say hello:
  //if (client) {
   // if (!alreadyConnected) {
      // clear out the input buffer:
    //  client.flush();
    //  Serial.println("We have a new client");
    //  client.println("Hello, client!");
    //  alreadyConnected = true;
    if (client.available() > 0) {
      // read the bytes incoming from the client:
      byte thisChar = client.read();
      //char thisChar = client.read();
      // echo the bytes back to the client:
      server.write(thisChar);
      // echo the bytes to the server as well:
      Serial.write(thisChar);
      mySerial.write(thisChar);
      //mySerial.println(thisChar);
  if (mySerial.available()) {
    byte serChar = mySerial.read();
    Serial.write(serChar);
    server.write(serChar);
But in com-port(3,5 pins) i have a bad symbols. Help me please. I want to get the same symbols that I send to the port ethernet. Port monitoring in IDE show me good symbols.
I'm use the sabj.
Say what?
Not on the Arduino.
It's pretty stupid to use the name of a type in the name of a variable, when the type used in the name is not the type of the variable. DO NOT DO THAT!
What is connected to pins 3 and 5? Please post a picture of your mySerial.
Thank you responded!
Say what?
I use Arduino Uno and shield W5100. My English is so bad? :wink:
Not on the Arduino.
But why? exchange only 4 packages per minute.
I agree. but this example was supplied with IDE. I did not change.
In example use pins 10&11, but that pins use in connected with Ethernet shield. I took 3 and 5 pins because near them drawn ~ as near 10 and 11 pins.
COM3 - port monitor in IDE, COM5 - 3&5 pins.
What do you have connected to the SoftSerial port?
I guess it is. I still have no idea what "I'm use the sabj." means.
That has NOTHING to do with needing, or not needing, an RS232 to TTL converter ON THE ARDUINO. If you meant something else, POST A LINK TO THE HARDWARE!
Which example? I'll post a complaint in the appropriate section if this is indeed true.
The original sketch used 10 and 11 because they are next to each other, not because they are PWM pins. And I still no not know what is connected to those pins. What I do know is that whatever the physical device is, it is NOT a mySerial, so that instance name is stupid.
aarg:
com-port of my computer. It works correctly, I checked.
AndreySaf:
That is the port that is receiving garbage? Double check that the baud rates on the Arduino and computer side are identical.
PaulS:
you think that I need a converter 232 <-> TTL? for example MAX232? inversion and a decrease in voltage? i'm stupid!!! I was looking for a bug in the code but the problem in the hardware. Thank you!
No. You are the one saying that you need one. YOU DO NOT!
Sorry, but I think the language barrier is creating misunderstandings here. Please give us a diagram of your system so we can understand how things are connected.
