Arduino UNO wakes up randomly
Hello everybody,
I'm building a food scale with a load cell-HX711 and a 4-digit seven segment display, I'd like to put the device in power down mode when not in use by pressing a button, I wrote the code but something is wrong with the power down mode: in few minutes Arduino wakes up by itself without no external input, I tried to google the forum but nothing helped, what's wrong with the sleep mode?
This is my code
#include "HX711.h"
#include "SevSeg.h"
#include <avr/sleep.h>
SevSeg sevseg;
HX711 scale;
int t, i, n = 20, T;
  double val, sum, sumsq, mean;
  float stddev;
  int sums;// sumsold, sums1, sums2, sums3, sums4, sumr3, sumr4;
  int pushtare = A2, pushsleep = 2;
  const int interval = 1000;
void Going_To_Sleep(){
    //digitalWrite(buzz,HIGH);
    set_sleep_mode(SLEEP_MODE_PWR_DOWN); // Sets the sleep mode
    cli();
    sleep_enable(); // set sleep bit
    attachInterrupt(0, wakeUp, LOW); // attach interrupt to wake CPU after sleep.
    digitalWrite(LED_BUILTIN, LOW); // turn off LED to show sleep mode
    sei();
    sleep_cpu(); // put to sleep - will wake up here.
    sleep_disable();
    detachInterrupt(0); //Removes the interrupt from pin 2;
    Serial.println("woke up"); // first line of code executed after sleep.
     scale.tare();
    digitalWrite(LED_BUILTIN, HIGH);//turning LED on
void wakeUp(){
  Serial.println("Interrrupt Fired");//Print message to serial monitor
  //detachInterrupt(digitalPinToInterrupt(2)); //Removes the interrupt from pin 2;
  // sleep_disable();//Disable sleep mode
  //detachInterrupt(0); //Removes the interrupt from pin 2;
  Serial.begin(9660);
  pinMode (pushtare, INPUT);
  pinMode (pushsleep, INPUT_PULLUP);
  //digitalWrite(pushsleep, HIGH);
   byte numDigits = 4;
  byte digitPins[] = {10, 11, 12, 13};
  byte segmentPins[] = {9, 3, A3, 5, 6, 8, 7, 4};
  bool resistorsOnSegments = true;
  bool updateWithDelaysIn = true;
  byte hardwareConfig = COMMON_CATHODE;
  sevseg.begin(hardwareConfig, numDigits, digitPins, segmentPins, resistorsOnSegments);
  sevseg.setBrightness(90);
  Serial.println("HX711 Demo");
  Serial.println("Initializing the scale");
  // parameter "gain" is ommited; the default value 128 is used by the library
  // HX711.DOUT  - pin #A1
  // HX711.PD_SCK - pin #A0
  scale.begin(A1, A0);
  Serial.print("Raw ave(20): \t\t");
  Serial.println(scale.read_average(20));   // print the average of 20 readings from the ADC
  // Scale factor:
  // 1Kg cell: 2020 for reading in gms
  // 50kg cells: 19150 for reading in kg
  scale.set_scale(421.f);                      // this value is obtained by calibrating the scale with known weights; see the README for details
  scale.tare();               // reset the scale to 0
  Serial.println("\nAfter setting up the scale:");
  Serial.print("Raw: \t\t\t");
  Serial.println(scale.read());                 // print a raw reading from the ADC
  Serial.print("Raw ave(5) - tare: \t");
  Serial.println(scale.get_value(5));   // print the average of 5 readings from the ADC minus the tare weight, set with tare()
  Serial.print("Calibrated ave(5): \t");
  Serial.println(scale.get_units(5), 1);        // print the average of 5 readings from the ADC minus tare weight, divided
            // by the SCALE parameter set with set_scale
  Serial.println("\nReadings:");
 unsigned long now2 = millis(); //prende il tempo
  while (millis() < now2 + interval) { //conta fino a del
  sevseg.setNumber(sums);
  //if (abs(sums - sumsold) > 5){
  sevseg.refreshDisplay();
  if (digitalRead(pushtare) == HIGH){
    scale.tare();
  if (digitalRead(pushsleep) == HIGH){
    Going_To_Sleep();
  //delay(500);
  bilancia();
  scale.power_down();             // put the ADC in sleep mode
  delay(5000);
  scale.power_up();
void bilancia(){
  n = 1;
  t = millis();
  sum = sumsq = 0;
  //while (i<n) {
    val = ((scale.read() - scale.get_offset()) / scale.get_scale());
    sum += val;
    sumsq += val * val;
  //  i++;
  t = millis() - t;
  mean = sum / n;
  //sumsold = sums;
  sums = mean;
  stddev = sqrt(sumsq / n - mean * mean);
  /*Serial.println("sono nel while");
  Serial.print("Mean, Std Dev of "); Serial.print(i); Serial.print(" readings:\t");
  Serial.print(sum / n, 2); Serial.print("\t"); Serial.print(stddev, 2);
  // Note: 2 sigma is 95% confidence, 3 sigma is 99.7%
  Serial.print("\nTime taken:\t"); Serial.print(float(t)/1000, 3); Serial.println("Secs\n");
  Serial.print("Mean: "); Serial.println(mean);
  Serial.print("Sum_int:"); Serial.println(sums);*/
  //Divide un numero in cifre singole
  /*sums4 = sums%10; //tratta l'unità come resto di una divisione e la mette in una variabile
  sumr4 = sums/10; //prende la parte restante del numero
  sums3 = sumr4%10; //tratta la come resto di una divisione e la mette in una variabile
  sumr3 = sumr4/10; //prende la parte restate del numero
  sums2 = sumr3%10; //tratta le centinaia come resto di una divisione e la mette in una variabile
  sums1 = sumr3/10; //prende le migliaia come numero
  //delay(1000);
P.S.: I noticed that if I leave blank the wakeUp() function Arduino wakes immediately after going to sleep, if I put in it the Serial.print message it remains asleep for few minutes, but the RX led remains turned on.
I think I solved the question by adding the scale.power_down() and scale.power_up functions of the HX711 library inside the GoingToSleep function this way
    cli();
    sei();
    scale.power_down();
    sleep_disable();
     scale.power_up();
     scale.tare();
