Arduino UNO WDT Not Working
Hello. I'm dealing with WDT. I wrote a simple test program but WDT is not working. What would be the reason? Note: I am using hex without bootloader.
<#include <avr/wdt.h>
const byte led = 2;
    pinMode(led, OUTPUT);
    digitalWrite(led, HIGH);
    digitalWrite(led, LOW);
    wdt_disable();
    wdt_enable(WDTO_8S);
    wdt_reset();
    delay(9000); //test delay
    wdt_reset();
This test I wrote a while back worked fine for me. When the blink interval got up to 500 milliseconds, the system reset.
//  Watchdog Timer Example
unsigned long ToggleDelay;  //  When this delay grows to longer than the WDT interval the WDT resets the Arduino
void toggle_led()
  digitalWrite(LED_BUILTIN, !digitalRead(LED_BUILTIN));
  wdt_disable();
  ToggleDelay = 10;   // Start with a very short delay
  pinMode(LED_BUILTIN, OUTPUT);
  wdt_enable(WDTO_500MS);  // Set watchdog to 1/2 second
  wdt_reset();
  toggle_led();   // Blinking goes slower and slower until the WDT causes reset, then starts over.
  delay(ToggleDelay);
  ToggleDelay += 10;   // Increase the delay by 10 milliseconds.
So you're uploading using a progammer? Is there a reason why you don't use the USB interface for sketch upload? Does your sketch work if you upload that way?
Yes I am installing with a programmer. Since the rx-tx pins are reserved for another function in my circuit, it is troublesome to load them with uart.
The wdt_reset() after wdt_enable() isn't necessary as wdt_enable() includes a reset of the timer.
You should reset MCUSR before everything else. (MCUSR = 0;)
Try to use a value of WDTO_4S for wed_enable() without chaning anything else in the code. Does that work?
