Arduino Uno weather project error help!
I'm trying to connect DHT11 and BMP085 along with a DC motor and a button to display on the LCD screen a few things: temperature, humidity, altitude, dew point, e.t.c.
This is my code below. However I am getting 5 errors.
  1. "e BMP temperature" = e does not name a type
  2. under void setup(), "DHT.11attach(DHT11PIN);" = 'class dht11' has no member named 'attach'
  3. under void loop(), "lcd.print(DHT11.dewPoint());" = 'class dht11' has no member named 'dewPoint'
  4. 125: error: 'ac1' was not declared in this scope
  5. 242: error: 'ac1' was not declared in this scope
So these are the 5 errors that I am getting that I can't seem to fix until i comment it out. if i comment it out well then the program doesn't work... Can someone help me with this?
// include the library codes:
#include <LiquidCrystal.h>
#include <Wire.h>
#include <dht11.h>
#include <Versalino.h>
// initialize the LCD with interface pins
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
// initialize start variables
int TempF;
int TempC;
int ADCvalue;
dht11 DHT11;
#define DHT11PIN 9
#define BMP_ADDRESS = 0x77
//These are are initialized globally, since the BMP085 pressure calculations require certain variables to have been calculated from t
e BMP temperature
int ac1;
int ac2;
int ac3;
unsigned int ac4;
unsigned int ac5;
unsigned int ac6;
int b1;
int b2;
int mb;
int mc;
int md;
long b5;
const unsigned char OSS = 0;
float atm;
float pressure;
int chk;
int fanPin = A0;
int fanValue = 0;
  //attach the DHT11 sensor to a pin
  DHT11.attach(DHT11PIN);
  //increase ADC resolution by only reading 0V - 1.1V
  analogReference(INTERNAL);
  // Initialize LCD columns and rows
  lcd.begin(20, 4);
  //Allow for serial communications at 9600 bits/s
  //Initialize communications using the Wire library
  Wire.begin();
  lcd.setCursor(0,0);
  //output humidity
  lcd.print("Humidity (%):");
  lcd.print(DHT11.humidity);
  //delay 1 sec and clear screen
  lcd.clear();
  //output dew point
  lcd.print("Dew point (C):");
  lcd.clear()  ;
  //calibrate the BMP085 sensor
  bmpCalibrate();
  //Output temperature from BMP in ºC
  lcd.print("Temp (C): ");
  lcd.print(bmpGetTemp(bmpReadUT()));
  lcd.clear();
  //Output pressure in atm
  lcd.print("Pressure (atm): ");
  pressure = bmpGetPressure(bmpReadUP());
  atm = pressure / 101325;
  lcd.print(atm);
  lcd.clear();
  //Output altitude in feet
  lcd.print("Altitude: ");
  lcd.print(getAltitude(pressure)*3.1);
  lcd.clear();
  //reads the voltage from the electric motor
  fanValue = analogRead(fanPin);
  //maps the voltage from the motor to return 1 if the voltage is
  //above 400mV
  fanValue = map(fanValue, 0, 800,0, 1);
  //outputs either high or low for wind speed based on the
  //mapped voltage value
  lcd.print("Wind speed: ");
  if (fanValue == 1){
    lcd.print("HIGH");
  else{
    lcd.print("LOW");
  lcd.clear();
//Restart the loop
//a method to calculate pressure from the BMP
float bmpGetPressure(unsigned long up){
  //Calulations to find pressure are derived from the BMP085 datasheet
  long x1, x2, x3, b3, b6, p;
  unsigned long b4, b7;
  b6 = b5 - 4000;
  // Calculate B3
  x1 = (b2 * (b6 * b6)>>12)>>11;
  x2 = (ac2 * b6)>>11;
  x3 = x1 + x2;
  b3 = (((((long)ac1)*4 + x3)<<OSS) + 2)>>2;
  // Calculate B4
  x1 = (ac3 * b6)>>13;
  x2 = (b1 * ((b6 * b6)>>12))>>16;
  x3 = ((x1 + x2) + 2)>>2;
  b4 = (ac4 * (unsigned long)(x3 + 32768))>>15;
  b7 = ((unsigned long)(up - b3) * (50000>>OSS));
  if (b7 < 0x80000000)
    p = (b7<<1)/b4;
    p = (b7/b4)<<1;
  x1 = (p>>8) * (p>>8);
  x1 = (x1 * 3038)>>16;
  x2 = (-7357 * p)>>16;
  p += (x1 + x2 + 3791)>>4;
  long temp = p;
  return temp;
//a method to return the dew point from the DHT11
//takes temp and humidity as parameters
double getDewPoint(double celsius, double humidity)
  //Equation is taken from NOAA dew point equation
  double A0= 373.15/(273.15 + celsius);
  double SUM = -7.90298 * (A0-1);
  SUM += 5.02808 * log10(A0);
  SUM += -1.3816e-7 * (pow(10, (11.344*(1-1/A0)))-1) ;
  SUM += 8.1328e-3 * (pow(10,(-3.49149*(A0-1)))-1) ;
  SUM += log10(1013.246);
  double VP = pow(10, SUM-3) * humidity;
  double T = log(VP/0.61078);   // temp var
  return (241.88 * T) / (17.558-T);
//calculates altitude based on the barometric pressure
//from the BMP085.  Requires pressure in pascal(Pa)
float getAltitude(float pressure){
  float A = pressure/101325;
  float B = 1/5.25588;
  float C = pow(A,B);
  C = 1 - C;
  C = C /0.0000225577;
  return C;
//gets temp from BMP085
float bmpGetTemp(unsigned int ut){
  //Equations from the BMP085 datasheet
  long x1;
  long x2;
  x1 = (((long)ut-(long)ac6)*(long)ac5)>>15;
  x2 = ((long)mc<<11)/(x1+md);
  b5 = x1 + x2;
  float temp = ((b5+8)>>4);
  temp = temp / 10;
  return temp;
//communicates with BMP sensor using the wire function
//Returns the value located at 0xF6 needed for the temperature
//Calculations
unsigned long bmpReadUT(){
  unsigned int ut;
  Wire.beginTransmission(0x77);
  Wire.write(0xF4);
  Wire.write(0x2E);
  Wire.endTransmission();
  delay(5);
  ut = bmpReadInt(0xF6);
  return ut;
//Writes several values to the BMP085 and waits for response
//Used the msb,lsb and xlsb to return the value needed to
//Calculate pressure
unsigned long bmpReadUP(){
  unsigned char msb, lsb, xlsb;
  unsigned long up = 0;
  Wire.write(0xF4);
  Wire.write(0x34 + (OSS<<6));
  delay(2+(3<<OSS));
  Wire.write(0xF6);
  Wire.requestFrom(0x77, 3);
  // Wait for data to become available
  while(Wire.available() < 3)
  //establish most and least significant bits
  msb = Wire.read();
  lsb = Wire.read();
  xlsb = Wire.read();
  up = (((unsigned long) msb << 16) | ((unsigned long) lsb << 8) | (unsigned long) xlsb) >> (8-OSS);
  return up;
//calibrates the BMP085 with known data values
void bmpCalibrate(){
  ac1 = bmpReadInt(0xAA);
  ac2 = bmpReadInt(0xAC);
  ac3 = bmpReadInt(0xAE);
  ac4 = bmpReadInt(0xB0);
  ac5 = bmpReadInt(0xB2);
  ac6 = bmpReadInt(0xB4);
  b1 = bmpReadInt(0xB6);
  b2 = bmpReadInt(0xB8);
  mb = bmpReadInt(0xBA);
  mc = bmpReadInt(0xBC);
  md = bmpReadInt(0xBE);
//reads the bits from the BMP085
int bmpReadInt(unsigned char address){
  unsigned char msb;
  unsigned char lsb;
  Wire.write(address);
  Wire.requestFrom(0x77,2);
  while(Wire.available()<2)
  msb = Wire.read();
  lsb = Wire.read();
  return (int) msb<<8 | lsb;
Moderator edit:
</mark> <mark>[code]</mark> <mark>
</mark> <mark>[/code]</mark> <mark>
tags added.
Proyecto.ino (6.08 KB)
e BMP temperature
When you cut and pasted the code, this bit from the stupid comment above it got wrapped and put on a new line. The idiot that wrote that code in the first place should have been whacked a few times for now using a multiline comment.
#define DHT11PIN 9
One of these is wrong. I'll leave it to you to figure out which one, and why. That way, you won't make the same mistake again.
  1. under void setup(), "DHT.11attach(DHT11PIN);" = 'class dht11' has no member named 'attach'
  2. under void loop(), "lcd.print(DHT11.dewPoint());" = 'class dht11' has no member named 'dewPoint'
So, why are you trying to call these non-existent methods?
which of the many DHT11 libraries do you use?
So I figured out the other errors. However one last problem I'm having is with line 66,
does the command lcd.print(DHT11.dewPoint()); exist? or does this depend on the library I'm using?
This is where i'm getting the library from http://arduino-info.wikispaces.com/DHT11-Humidity-TempSensor
//output dew point
lcd.clear()
No. There is no command with that name. Of course, there are no commands in C or C++, so your question is meaningless.
The "command" you are asking about involves two method calls. One calls the dewPoint() method on the DHT11 instance. The other calls the print() method of the lcd instance.
The dht11 library, which DHT11 is an instance of, on Terry's page, does not have a dewPoint() method.
