arduino uno web server stops responding after a week or so
Hello there Im new to arduino world, i have taken a web server sketch and heavily modified it so i can power on/off my computer using 2 relays from the web after entering a password.
the sketch works ok for about a week or so and then arduino stops serving the website.
The strange thing is that while the website isnt served anymore, if i open arduino ide and enable serial output then arduino immediately starts serving the page again!
im trying my best but i cant figure out why it stops responding.
the correct password to operate the relays is 8452 or 8425 both passwords produce the same value on the pin variable by the math operations i selected so both of them will work.
the code is the following
can anyone please help me figure out why arduino stops responding?
#include <SPI.h>
#include <Ethernet.h>
EthernetServer server(80);// Server port
const byte reset = 5;// Select pin for reset
const byte power = 6;// Select pin for power
int pin =0;          // Password Value
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };// Physical MAC address
byte ip[] = { 192, 168, 1, 178 };// Fixed IP address
byte gateway[] = { 192, 168, 1, 1 };// Router Gateway Internet access
byte subnet[] = { 255, 255, 255, 0 };// Subnet mask
String readString;
delay(300);// Delay for Ethernet shield initialization (Arduino has 65mS Power Up delay and W5100 reset logic has 280mS)
pinMode(reset, OUTPUT);// Define pin for reset as Output
pinMode(power, OUTPUT);// Define pin for power as Output
Serial.begin(9600);// Initialize serial communications at 9600 bps
Serial.println(F("Arduino UNO R3 with Ethernet Shiled W5100 - VU3GAO"));// Display Arduino title
Ethernet.begin(mac, ip, gateway, subnet);// Start Ethernet
server.begin();
Serial.print(F("Ethernet Shield initialized. Local IP address is:"));
Serial.println(Ethernet.localIP());// Print Server IP address
EthernetClient client = server.available();// Create a client connection
if (client == true)
while (client.connected())
if (client.available())
char c = client.read();// Read char by char HTTP request
if (readString.length() < 100)
readString = readString + c;// Store characters to string
if (c == '\n')
Serial.println(readString);
client.println(F("http/1.1 200 ok"));// Send standard http headers
client.println(F("content-type: text/html"));
client.println();
client.println(F("<!doctype html><html>"));
client.println(F("<body bgcolor='9ec3c3'>"));
client.println(F("<center><head><title>Home Web Control</title></head>"));
client.println(F("<h2>Arduino UNO R3 Ethernet Shield Web Server(v2.16)</h2>"));
client.println(F("<h4>Home Automation With Arduino</h4>"));
client.println(F("
<hr/><p> Enter The Correct Password To Turn On And OFF <p/><hr/>
client.print(F("
client.print(F("<input type=button value='&nbsp;1&nbsp;' onmousedown=location.href='/?1_on'>"));
client.print(F("&nbsp;"));
client.print(F("<input type=button value='&nbsp;2&nbsp;' onmousedown=location.href='/?2_on'>"));
client.print(F("<input type=button value='&nbsp;3&nbsp;' onmousedown=location.href='/?3_on'>"));
client.print(F("
client.print(F("<input type=button value='&nbsp;4&nbsp;' onmousedown=location.href='/?4_on'>"));
client.print(F("<input type=button value='&nbsp;5&nbsp;' onmousedown=location.href='/?5_on'>"));
client.print(F("<input type=button value='&nbsp;6&nbsp;' onmousedown=location.href='/?6_on'>"));
client.print(F("
client.print(F("<input type=button value='&nbsp;7&nbsp;' onmousedown=location.href='/?7_on'>"));
client.print(F("<input type=button value='&nbsp;8&nbsp;' onmousedown=location.href='/?8_on'>"));
client.print(F("<input type=button value='&nbsp;9&nbsp;' onmousedown=location.href='/?9_on'>"));
client.print(F("
client.print(F("<input type=button value='&nbsp;*&nbsp;' onmousedown=location.href='/?AK_on'>"));
client.print(F("<input type=button value='&nbsp;0&nbsp;' onmousedown=location.href='/?0_on'>"));
client.print(F("<input type=button value='&nbsp;#&nbsp;' onmousedown=location.href='/?HS_on'>"));
client.print(F("
client.print(F("<input type=button value='Reset' onmousedown=location.href='/?RS_on'>"));
client.print(F("<input type=button value='Power' onmousedown=location.href='/?PW_on'>"));
client.print(F("
client.println(F("
<hr/><p> Home Automation With Arduino <p/>"));
client.println(F("</body></html>"));
delay(1);// Page loading delay
client.stop();// Stopping client
//numbers 8,4,5,2 are make a math operation in order to have the pin variable get the number 25
          if (readString.indexOf("/?1_on") >0) //set pin value of the button 1
               pin = 0;
               Serial.print("PIN= ");
               Serial.println(pin);
  delay(1);
           if (readString.indexOf("/?2_on") >0)  //set pin value of the button 2
               pin = pin - 2;
  delay(1);
           if (readString.indexOf("/?3_on") >0)  //set pin value of the button 3
               pin = 0;
  delay(1);
           if (readString.indexOf("/?4_on") >0)  //set pin value of the button 4
               pin = pin * 4;
  delay(1);
           if (readString.indexOf("/?5_on") >0)  //set pin value of the button 5
               pin = pin - 5;
  delay(1);
           if (readString.indexOf("/?6_on") >0)  //set pin value of the button 6
               pin = 0;
  delay(1);
           if (readString.indexOf("/?7_on") >0)  //set pin value of the button 7
               pin = 0;
  delay(1);
           if (readString.indexOf("/?8_on") >0)  //set pin value of the button 8
               pin = pin + 8;
  delay(1);
           if (readString.indexOf("/?9_on") >0)  //set pin value of the button 9
               pin = 0;
  delay(1);
           if (readString.indexOf("/?AS_on") >0)//set pin value of the button *
               pin = 0;
  delay(1);
           if (readString.indexOf("/?0_on") >0)  //set pin value of the button 0
               pin = 0;
  delay(1);
           if (readString.indexOf("/?HS_on") >0)  //set pin value of the button #
               pin = 0;
  delay(1);
if(readString.indexOf("/?RS_on") > 0 && pin == 25) //if reset button is pressed and the password is correct enable the relay
               digitalWrite(reset, HIGH);
               digitalWrite (reset, LOW);
              pin = 0;
  delay(1);
if(readString.indexOf("/?PW_on") > 0 && pin == 25) //if power button is pressed and the password is correct enable the relay
               digitalWrite(power, HIGH);
               digitalWrite (power, LOW);
               pin = 0;
  delay(1);
readString = "";// Clearing string for next read
}// End of line reached
}// End of client available
}// End of client connected
}// End of client connection
}// End of loop
Opening the IDE serial monitor reboots the arduino.
jimacid: can anyone please help me figure out why arduino stops responding?
I'd suppose, that your programming logic allows client connections to be established, which will never be stopped then.
So perhaps your Ethernet shield networking may run out of connections after some time.
I'd better stop every client connection that had been established.
   delay(1);// Give some time to stop
I'd also limit the duration of the client connection to a maximum time. So if a malware client connects with a connection and keeps the connection for unlimited time, the condition "while (client.connected())" will be true forever. I'd better use a timeout (10 seconds or so) to prevent unlimited looping in the "while (client.connected())" loop.
BTW: Using the dynamic "String" object class is a good way to fragment the RAM on the long run. I'd better avoid the usage of every "String" object and just use C-strings (nullterminated char arrays) instead.
BTW: As zoomkat just wrote, every opening of the serial monitor will reset the microcontroller and your program starts a new run after a reset.
hmm ok thats why it starts working again after opening serial monitor.
i allready updated the project with the extra piece of code you gave me, hopefully it will do the trick. we will know in about a week 8)
if it stops serving again ill try the connection timeout to see if this helps.
thank you very much both of you.
ill keep my fingers crossed
The arduino auto reset can be defeated with a resistor or capacitor if needed. You might add some socket status code for debugging purposes when the lockup occurs.
