Hello Everyone,
This is one of my first posts so go easy on me! I have been playing around with the Uno connected to an w5100 ethernet sheild to control my hot water heater remotely via a webserver.
Now I have managed to get my head round most things with a bit of cut and paste and a bit of my own logic etc but there is this one thing that I can not sort out.
It all works fine apart from that when I switch the output on (Will be a relay but is an LED at the moment) and leave the webpage all is fine. It stays on until I revisit the page and then the LED flashes once and then goes off. If you leave the output off and then come back to the page it stays off. It is just when it is surposed to stay on that it does not.
Any ideas???
Cheers
#include <SPI.h>
#include <Ethernet.h>
byte mac[] = { 0x90, 0xA2, 0xDA, 0x0F, 0x9C, 0xCD }; // MAC address from Ethernet shield sticker under board
IPAddress ip(192,168,2,20); // IP address, may need to change depending on network
byte gateway[] = { 192, 168, 2, 1 }; //Routers IP Address to which your shield is connected.
byte subnet[] = { 255, 255, 255, 0 }; //It will be as it is in most of the cases
EthernetServer server(80); //create a server at port 80
String readString;
int HW_relay = 0; // state of hot water relay, off by default at start/reset/power on
void setup(){
//pins selected to control
pinMode(3, OUTPUT);
//start Ethernet
Ethernet.begin(mac, ip, gateway, gateway, subnet);
server.begin();
//enable serial data print
void loop(){
// Create a client connection
if (client) {
while (client.connected()) {
if (client.available()) {
char c = client.read();
//read char by char HTTP request
if (readString.length() < 100) {
//store characters to string
readString += c;
//Serial.print(c);
//if HTTP request has ended
if (c == '\n') {
Serial.println(readString); //print to serial monitor
client.println("HTTP/1.1 200 OK"); //send new page
client.println("Content-Type: text/html");
client.println();
client.println("<HTML>");
client.println("<HEAD>");
client.println("<TITLE>Home Automation Hub</TITLE>");
client.println("</HEAD>");
client.println("<BODY>");
client.println("<meta name='viewport' content='width=device-width'; initial-scale=1.0; maximum-scale=1.0;>"); //size page for mobile devices
//Control buttons for output pin 3
client.println("<h1>Hot Water</h1>");
client.print("<input type=submit value=ON style=width:100px;height:45px onClick=location.href='/?on2'>");
client.print(" <input type=submit value=OFF style=width:100px;height:45px onClick=location.href='/?off3'>");
//////Check for button press and switch output on or off/////
if(readString.indexOf('2') >0) //see if ON button was clicked and switch relay if 2 found
digitalWrite(3, HIGH);
client.println(" <font color='green'>ON</font"); //show status on
//if(readString.indexOf('3') >0) //see if OFF button was clicked and switch relay if 3 found
digitalWrite(3, LOW);
client.println(" <font color='red'>OFF</font"); //show status off
client.println("</BODY>");
client.println("</HTML>");
delay(1);
//stopping client
client.stop();
//clearing string for next read
readString="";
If there is not a '2' in the GET string, the LED is turned off. If you uncomment the second readString.indexOf, it probably won't turn off. It is common for the web browser to request a file called favicon.ico after it loads the webpage. That would cause the LED to turn on (webpage request) and then off (favicon request).
Thanks for the reply. Forgot that was commented out. I was playing around to try and get it to work, I did that when i put in the else command. It still works the same with the line not commented and the else got rid of.
In your code you need to change the String search from a single character (which may be in several places in the returned header) to a multi character String like below.
Yes I intend to have more than just one relay in the end doing different things so I was thinking of changing the search to look for more to save errors later.
Its all working apart from that darn output going high when I leave the relay off then navigate away from the server onto another site, return to the Arduino and it sets the output to on if it was off!
Any further ideas anyone? I will have to investigate the favicon thing...
Well, almost have it working the way I want but when you first navigate to the server it would be great to see the current state of the outputs before any buttons are pressed. So far I have tried to call the state of the outputs and display them but I end up with two on's or two off's displayed! Another one I tried it end up having to press either button twice!
Its getting late and I have totally fried my brain....
Anyway, here is the sort of working sketch it just does not display the state on initial page load.
Any ideas anyone??
Cheers
Crumpy
PS Thought I would implement the extra char in the string, thanks for reminding me Zoomkat!
#include <SPI.h>
String readString;
// constants won't change. They're used here to set pin numbers:
const int HW_relay = 3; //Hot water relay set on pin 3
// variables will change
int HW_relay_state = 0; // state of hot water relay, off by default at start/reset/power on
void setup(){
pinMode(HW_relay, OUTPUT); //Hot water pin set as output
//start Ethernet
server.begin();
void loop(){
if (client) {
readString += c;
//Serial.print(c);
if (c == '\n') {
client.println();
//Control buttons for Hot Water relay on output pin 3
//////Check for button press and switch outputs on or off/////
if(readString.indexOf('on2') >0) //see if ON button was clicked and switch relay on if 2 found
digitalWrite(HW_relay, HIGH);
if(readString.indexOf('off3') >0)
digitalWrite(HW_relay, LOW);
delay(1);
//stopping client
client.stop();
readString="";
I evaluate the request string (character array) for more than just those characters. I insure the page requested is correct among other parameters. http://playground.arduino.cc/Code/WebServerST
For your other question, I would try this.
if(readString.indexOf("on2") >0) //see if ON button was clicked and switch relay on if 2 found
else if(readString.indexOf("off3") >0)
else if(digitalRead(HW_relay) == LOW) // check the pin for LOW state
