Arduino UNO + Wifi + R3 + ATMega328P + ESP8266 CH340: Upload Sketch
Hi all,
I have an Arduino UNO + Wifi + R3 + ATMega328P.
I am triyng to upload some simple sketch but I always receive errors after upload.
I think I am not selecting properly the board in the Arduino IDE software. Please can someone advise ?
Thanks in advance.
Carlos.
Please do this:
  • (In the Arduino IDE) File > Preferences
  • Uncheck the checkbox next to "Show verbose output during: compilation"
  • Check the checkbox next to "Show verbose output during: upload
  • Click "OK"
  • Sketch > Upload
  • After the upload fails, you'll see a button on the right side of the orange bar "Copy error messages" (or the icon that looks like two pieces of paper at the top right corner of the black console window in the Arduino Web Editor). Click that button.
  • In a forum reply here, click on the reply field.
  • Click the </> button on the forum toolbar. This will add the forum's code tags markup to your reply.
  • Press "Ctrl + V". This will paste the upload output between the code tags.
  • Move the cursor outside of the code tags before you add any additional text to your reply.
Please provide more information about this Arduino UNO + Wifi + R3 + ATMega328P. I'm not familiar with this.
Is this one of those boards with the DIP switches?
Not straight forward to use.
https://robotdyn.com/uno-wifi-r3-atmega328p-esp8266-32mb-flash-usb-ttl-ch340g-micro-usb.html
READ ---> Robotdyn atmega328 uno r3 + Wifi. How to use it? - Networking, Protocols, and Devices - Arduino Forum
Arduino:1.8.13 (Windows 10), Tarjeta:"Arduino Uno"
El Sketch usa 1486 bytes (4%) del espacio de almacenamiento de programa. El máximo es 32256 bytes.
Las variables Globales usan 200 bytes (9%) de la memoria dinámica, dejando 1848 bytes para las variables locales. El máximo es 2048 bytes.
C:\Users\usuario\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/bin/avrdude -CC:\Users\usuario\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf -v -patmega328p -carduino -PCOM5 -b115200 -D -Uflash:w:C:\Users\usuario\AppData\Local\Temp\arduino_build_738630/sketch_mar11a.ino.hex:i
avrdude: Version 6.3-20190619
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "C:\Users\usuario\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf"
         Using Port                    : COM5
         Using Programmer              : arduino
         Overriding Baud Rate          : 115200
         AVR Part                      : ATmega328P
         Chip Erase delay              : 9000 us
         PAGEL                         : PD7
         BS2                           : PC2
         RESET disposition             : dedicated
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           eeprom        65    20     4    0 no       1024    4      0  3600  3600 0xff 0xff
           flash         65     6   128    0 yes     32768  128    256  4500  4500 0xff 0xff
           lfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           hfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           efuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           lock           0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
         Programmer Type : Arduino
         Description     : Arduino
         Hardware Version: 3
         Firmware Version: 4.4
         Vtarget         : 0.3 V
         Varef           : 0.3 V
         Oscillator      : 1.176 kHz
         SCK period      : 3.3 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.00s
avrdude: Device signature = 0x1e950f (probably m328p)
avrdude: reading input file "C:\Users\usuario\AppData\Local\Temp\arduino_build_738630/sketch_mar11a.ino.hex"
avrdude: writing flash (1486 bytes):
Writing | ################################################## | 100% 0.27s
avrdude: 1486 bytes of flash written
avrdude: verifying flash memory against C:\Users\usuario\AppData\Local\Temp\arduino_build_738630/sketch_mar11a.ino.hex:
avrdude: load data flash data from input file C:\Users\usuario\AppData\Local\Temp\arduino_build_738630/sketch_mar11a.ino.hex:
avrdude: input file C:\Users\usuario\AppData\Local\Temp\arduino_build_738630/sketch_mar11a.ino.hex contains 1486 bytes
avrdude: reading on-chip flash data:
avrdude: stk500_paged_load(): (a) protocol error, expect=0x10, resp=0x00
####avrdude: stk500_cmd(): programmer is out of sync
avr_read(): error reading address 0x0000
    read operation not supported for memory "flash"
avrdude: failed to read all of flash memory, rc=-2
avrdude: stk500_disable(): protocol error, expect=0x14, resp=0x00
avrdude done.  Thank you.
Este informe podría contener más información con
"Mostrar salida detallada durante la compilación"
opción habilitada en Archivo -> Preferencias.
Hi everyone,
first of all, thanks for your answer.
I have followed the instructions indicated and above you can see the error messages received triyng to upload a simple sketch ("Hello Word").
Below you can see the configuration I am using:
  • Board: Arduino UNO + Wifi + R3 + ATMega328P + ESP8266 CH340 with DIP switches.
  • Arduino IDE configuration: Board Arduino UNO
  • DIP Switches configuration: 1OFF, 2OFF, 3ON, 4ON, 5OFF, 6OFF, 7OFF, 8OFF
Thanks in advance for your help.
Carlos.
cdmmez:
Huh? I would need to see a schematic or block diagram to make sense of this.
SteveMann:
There is no schematic.
It is a board made by Robotdyn. I linked it above.
cdmmez:
Using Port                    : COM5
PAGEL                        : PD7
BS2                          : PC2
RETRY pulse                  : SCK
Timeout                      : 200
StabDelay                    : 100
CmdexeDelay                  : 25
SyncLoops                    : 32
ByteDelay                    : 0
PollIndex                    : 3
PollValue                    : 0x53
Memory Detail                :
Hardware Version: 3
Vtarget        : 0.3 V
Varef          : 0.3 V
SCK period      : 3.3 us
Hi everyone,
- Board: Arduino UNO + Wifi + R3 + ATMega328P + ESP8266 CH340 with DIP switches.
- Arduino IDE configuration: Board Arduino UNO
- DIP Switches configuration: 1OFF, 2OFF, 3ON, 4ON, 5OFF, 6OFF, 7OFF, 8OFF
Carlos.
I am guessing that the "Hello World" sketch prints to the Serial Monitor?
Do you have another board to try?
/* Comment this out to disable prints and save space */
#define BLYNK_PRINT Serial
#include <ESP8266_Lib.h>
#include <BlynkSimpleShieldEsp8266.h>
// You should get Auth Token in the Blynk App.
// Go to the Project Settings (nut icon).
char auth[] = "I1SMrSaKeYD1PwAPcJhBcGpuAqOXlAOz";
// Your WiFi credentials.
// Set password to "" for open networks.
char ssid[] = "YourNetworkName";
char pass[] = "YourPassword";
// Hardware Serial on Mega, Leonardo, Micro...
//#define EspSerial Serial1
// or Software Serial on Uno, Nano...
#include <SoftwareSerial.h>
SoftwareSerial EspSerial(2, 3); // RX, TX
// Your ESP8266 baud rate:
#define ESP8266_BAUD 115200
ESP8266 wifi(&EspSerial);
BlynkTimer timer;
// This function sends Arduino's up time every second to Virtual Pin (5).
// In the app, Widget's reading frequency should be set to PUSH. This means
// that you define how often to send data to Blynk App.
void myTimerEvent()
  // You can send any value at any time.
  // Please don't send more that 10 values per second.
  Blynk.virtualWrite(V5, millis() / 1000);
  // Debug console
  // Set ESP8266 baud rate
  EspSerial.begin(ESP8266_BAUD);
  delay(10);
  Blynk.begin(auth, wifi, ssid, pass);
  // You can also specify server:
  //Blynk.begin(auth, wifi, ssid, pass, "blynk-cloud.com", 80);
  //Blynk.begin(auth, wifi, ssid, pass, IPAddress(192,168,1,100), 8080);
  // Setup a function to be called every second
  timer.setInterval(1000L, myTimerEvent);
  Blynk.run();
  timer.run(); // Initiates BlynkTimer
Hi all, finally I could upload the "Hello Word" sketch.
Now I am in the next step, it means, try to work with the embedded wifi ESP8266 module.
I can send AT commands to the ESP8266 without problems, in fact, the module is connected to the wifi.
But when I try to upload the above sketch to use arduino with blynk app I receive the below error messages. Please advise:
El Sketch usa 17866 bytes (55%) del espacio de almacenamiento de programa. El máximo es 32256 bytes.
Las variables Globales usan 1133 bytes (55%) de la memoria dinámica, dejando 915 bytes para las variables locales. El máximo es 2048 bytes.
C:\Users\usuario\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/bin/avrdude -CC:\Users\usuario\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf -v -patmega328p -carduino -PCOM6 -b115200 -D -Uflash:w:C:\Users\usuario\AppData\Local\Temp\arduino_build_892006/Arduino_WiFi_Shield.ino.hex:i
         Using Port                    : COM6
         PAGEL                         : PD7
         BS2                           : PC2
         RETRY pulse                   : SCK
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
         Hardware Version: 3
         Vtarget         : 0.3 V
         Varef           : 0.3 V
         Oscillator      : 28.800 kHz
         SCK period      : 3.3 us
avrdude: reading input file "C:\Users\usuario\AppData\Local\Temp\arduino_build_892006/Arduino_WiFi_Shield.ino.hex"
avrdude: writing flash (17866 bytes):
Writing | ###########################avrdude: loadaddr(): (b) protocol error, expect=0x14, resp=0xfc
#######avrdude: stk500_loadaddr(): (a) protocol error, expect=0x14, resp=0x10
########## | 100% 3.17s
avrdude: 17866 bytes of flash written
avrdude: verifying flash memory against C:\Users\usuario\AppData\Local\Temp\arduino_build_892006/Arduino_WiFi_Shield.ino.hex:
avrdude: load data flash data from input file C:\Users\usuario\AppData\Local\Temp\arduino_build_892006/Arduino_WiFi_Shield.ino.hex:
avrdude: input file C:\Users\usuario\AppData\Local\Temp\arduino_build_892006/Arduino_WiFi_Shield.ino.hex contains 17866 bytes
Reading | ###
el puerto seleccionado
 no existe o tu placa no esta conectada
Hi all,
I am not sure if I am selecting the correct board in the Arduino IDE.
The question is that I can upload the below "Hello Word" simple skecth and see the results in the serial monitor, but I receive some errors uploading the sketch (see at the end of this post):
Code:
// Debug console
Serial.println("Hello World");
// Blynk.run();
Error:
C:\Users\usuario\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/bin/avrdude -CC:\Users\usuario\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf -v -patmega328p -carduino -PCOM6 -b115200 -D -Uflash:w:C:\Users\usuario\AppData\Local\Temp\arduino_build_933125/Arduino_org_UNO_WiFi.ino.hex:i
         Using Port                    : COM6
         PAGEL                         : PD7
         BS2                           : PC2
         RETRY pulse                   : SCK
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
         Hardware Version: 3
         Vtarget         : 0.3 V
         Varef           : 0.3 V
         SCK period      : 3.3 us
Reading | ################################################## | 100% 0.01s
avrdude: reading input file "C:\Users\usuario\AppData\Local\Temp\arduino_build_933125/Arduino_org_UNO_WiFi.ino.hex"
avrdude: verifying flash memory against C:\Users\usuario\AppData\Local\Temp\arduino_build_933125/Arduino_org_UNO_WiFi.ino.hex:
avrdude: load data flash data from input file C:\Users\usuario\AppData\Local\Temp\arduino_build_933125/Arduino_org_UNO_WiFi.ino.hex:
avrdude: input file C:\Users\usuario\AppData\Local\Temp\arduino_build_933125/Arduino_org_UNO_WiFi.ino.hex contains 1486 bytes
Reading |
Ha ocurrido un error mientras se enviaba el sketch
I don't have this board.
Try putting the Serial.println("hello world"); inside loop() and put a delay(1000);.
