ARDUINO UNO WIFI R3 (Dev Edition) Send simple http get request
I need send http request to my own server from arduino uno.
First of all I connected the board through web client configurator.
I tried different codes, the last one is:
File: RestClient.ino
This example makes an HTTP request after 10 seconds and shows the result both in
serial monitor and in the wifi console of the Arduino Uno WiFi.
Note: works only with Arduino Uno WiFi Developer Edition.
http://www.arduino.org/learning/tutorials/boards-tutorials/restserver-and-restclient
#include <Wire.h>
#include <UnoWiFiDevEd.h>
  const char* connector = "rest";
  const char* server = "<MY IP>";
  const char* method = "GET";
  const char* resource = "/";
  Serial.println("prima");
  Ciao.begin();
  Serial.println("dopo");
  pinMode(2, INPUT);
  //delay(1000);
  doRequest(connector, server, resource, method);
void doRequest(const char* conn, const char* server, const char* command, const char* method){
  Serial.println("Im doing the request");
  CiaoData data = Ciao.write(conn, server, command, method);
  if (!data.isEmpty()){
    Ciao.println( "State: " + String (data.get(1)) );
    Ciao.println( "Response: " + String (data.get(2)) );
    Serial.println( "State: " + String (data.get(1)) );
    Serial.println( "Response: " + String (data.get(2)) );
  else{
    Ciao.println ("Write Error");
    Serial.println ("Write Error");
But I get “Write Error” and the server does not recive any request
  const char* server = "google.com";
Since when did you buy google.com?
Of course I changed the url, I would not publish the server ip
chri97: Of course I changed the url, I would not publish the server ip
So, that's not really the code you are running.
Why did you change the code in your post after I commented on it? That was rude.
https://arduino.stackexchange.com/questions/66211/arduino-uno-wifi-r3-dev-edition-send-simple-http-get-request
