Arduino Uno wifi rev 2 connection
Hello everyone, I do not know if anyone of you who uses the Arduino Uno wifi rev 2 card. I have been in the programming world for a few months and I'm doing a project where I need the data captured by a sensor to arrive at the PC through the wifi. My problem is that Arduino connects to the wifi but when I select the Wi-Fi port and open the serial monitor tells me that the door is busy and I can not understand why ... also gives me another error that I says: error when downloading http://digistump.com/pachage_digistump_index.json and I do not understand what you can depend on! Would anyone know how to help me? I'm using the sketch of WiFiNINA examples just to see if everything is ok ... but also with that gives me the same problem
Aldina91:
Is that the exact and complete text of the error message?
Aldina91:
That's because you spelled it wrong. It should be:
http://digistump.com/package_digistump_index.json
Yeah but in the error i have pachage with c no k
The problem is that I can connect to the wifi but to exchange data from arduino to the PC how can I communicate? A sensor is connected to the Arduino and I should receive the data on the PC through the Wi-Fi connection.
Aldina91:
I don't understand what that means. It's most helpful if you post the exact error message. In your previous post, the error message clearly shows that you put an "h" where a "k" should be in the URL:
Aldina91:
The word is PACKAGE, not PACHAGE!
To fix this error, correct the URL at File > Preferences > Additional Boards Manager URLs.
Aldina91:
You can communicate however you like. There are many options. Probably the easiest is for the Uno WiFi Rev2 to create a webserver. Then you can just open the IP address of the webserver in the browser on your PC and see the data. There is an example sketch for a webserver on the Uno WiFi Rev2 here:
https://www.arduino.cc/en/Tutorial/WiFiNINAWiFiWebServer
Yeah thanks, I saw this... but.. how I can send a date from sensor to Arduino software with WiFi? It’s possible?
Aldina91:
The question doesn't make sense. Please provide a detailed description of what you're trying to accomplish.
yes i'm sorry!! I connected the sensor MPU6050 to Arduino, I would like to receive the sensor data on the PC with the wifi, not having the arduino board connected via USB. The card connects to the wifi without problems, but when I remove usb I do not have a port where I can send the data
