Hello everybody,
Is it possible to load datas (i.e. HTML code) in flash memory to make a real server on an Arduino Wifi rev2 using this kind of prog: const char html_code PROGMEM = R"=====(xyz.......)====";
Thanks
Michel
That will work, but you have to make sure that the number of = signs is balanced in your example.
yes, the numbers of '=' is balanced in my prog, i've just forgotten one when i wrote my question.
In fact, my sketch compiles, but i can't get back the characters when i answer the client:Client.println(HTML_code);
That is the downside of using progmem.
You can get the characters by using the pgm_read_byte function.
You could try something like this.
char c = -1;
for (size_t i = 0; c; i++) {
c = pgm_read_byte(html_code + i);
Serial.print(c);
Thank you very much for this solution which runs. Sorry but i don't understand the syntax: for (size_t i = 0; c; i++)
I presume you know what the following means?
for (int i = 0; i < 10; i++)
The for-loop ends when the stop condition i < 10 is no longer true. In the snippet shared in post #4, we use a different stop condition: the character that we read from FLASH should not be zero (which indicates the end of the string).
for (int i = 0; c != 0; i++)
This can be abbreviated to:
for (int i = 0; c; i++)
And since we are using an array (sort of), it is customary to use the type size_t instead of int.
[edit]
P.S. Please mark the most helpful post as the solution, it prevents helpers spending time on a solved issue and it will lead people with the same question to the right answer directly.
Thanks jfjlaros
You helped me so much. I learn every day something new with this community.
Kind regards. Michel
I re-open this thread with an other solution:
client.print((__FlashStringHelper*) page_html);
