Arduino UNO Wifi Rev2 Temperature Sensor Error Message
Hey!
The error message: 'One_Wire_Bus' was not declared in this scope
came when I tried verifying my code below:
#include<OneWire.h>
#include <DallasTemperature.h>
#define ONE_WIRE_BUS 7;
OneWire OneWire(One_Wire_Bus);
DallasTemperature sensors(&oneWire);
int numberSensors = 0;
float temperature;
void setup(void)
  sensors.begin();
  numberSensors = sensors.getDeviceCount();
  Serial.print(numberSensors);
  Serial.println("Sensors Found");
  sensors.requestTemperatures();
  for(int i = 0; i < numberSensors; i++)
    Serial.print("Sensor: ");
    Serial.print(i);
    Serial.print(" = ");
    temperature = sensors.getTempCByIndex(i);
    Serial.print(DallasTemperature::toFahrenheit(temperature));
    Serial.print((char)176);
    Serial.println("F");
  delay(2000);
Error Code:
C:\Users\Toddl\OneDrive\Documents\Arduino\Temperature_Rough_Draft\Temperature_Rough_Draft.ino:5:17: error: 'One_Wire_Bus' was not declared in this scope
C:\Users\Toddl\OneDrive\Documents\Arduino\Temperature_Rough_Draft\Temperature_Rough_Draft.ino:5:17: note: suggested alternative: 'OneWire_h'
                 OneWire_h
C:\Users\Toddl\OneDrive\Documents\Arduino\Temperature_Rough_Draft\Temperature_Rough_Draft.ino:6:28: error: 'oneWire' was not declared in this scope
C:\Users\Toddl\OneDrive\Documents\Arduino\Temperature_Rough_Draft\Temperature_Rough_Draft.ino:6:28: note: suggested alternative: 'OneWire'
                            OneWire
exit status 1
Compilation error: 'One_Wire_Bus' was not declared in this scope
Welcome to the forum
Please copy the full error message using the "Copy error message" button in the IDE and post it here in < CODE/ > tags
Check capitalization, OneWire vs oneWire:
// Setup a oneWire instance to communicate with any OneWire devices
OneWire oneWire(ONE_WIRE_BUS);
This was exactly the problem. Such a rookie mistake *facepalm
Thanks!
