Arduino Uno WiFi Rev2 Wifinina lost module
Hello All,
That drive me nuts!
I have a project that on a Uno Wifi Rev2, and after a while (30 minutes or so) I got an error telling me that the WifiNinna is not connected anymore, error code 255 whe I do a WiFi.status.
I'm using a IDE 2.0.3, I don't know what is the status of this WifiNina module, but a read a lot about it, event that it's a piece of crap (sorry).
So I don't know if I should go further or if it's still a prototype with many failure on it!
I don't event think my code is wrong, since I just check the Wifi status, and if ok I send something.
  Serial.println(F("\nStarting connection to server..."));
  if ( WiFi.status() != WL_CONNECTED ) {
    setColor( 255,0,0); // red until wifi is OK
    Serial.println(WiFi.status());
    initWifi();
And in initWifi it's the usual that you can find on the example wfifi web client, and just stop here :
   // check for the WiFi module:
  if (WiFi.status() == WL_NO_MODULE) {
    Serial.println(F("Communication with WiFi module failed!"));
    // don't continue
    while (true);
No Need to go further i't wont work.
So is there a real solution, or should I left the arduino for real project/production stuff ?
Thanks for any Input
does it happen with the WevServer example?
No my code is based on webclient.
I can give all my code, but it's 6 files, and use some SolTop vbus, 3 max31865 and a LCD display
So I don't know how to share a zip file!
That's the Wifi part:
void initWifi(){
    // don't continue
    while (true);
 // Print firmware version on the module
  String fv = WiFi.firmwareVersion();
  Serial.print("Firmware version installed: ");
  Serial.println(fv);
  if (fv < WIFI_FIRMWARE_LATEST_VERSION) {
    Serial.println(F("Please upgrade the firmware"));
  // attempt to connect to WiFi network:
  while (status != WL_CONNECTED) {
    Serial.print(F("Attempting to connect to SSID: "));
    Serial.println(ssid);
    // Connect to WPA/WPA2 network. Change this line if using open or WEP network:
    status = WiFi.begin(ssid, pass);
    // wait 5 seconds for connection:
    delay(5000);
  Serial.println(F("Connected to WiFi"));
  setColor( 0,0,255); // red until wifi is OK
  printWifiStatus();
  setColor( 0,255,0);
void printWifiStatus() {
  // print the SSID of the network you're attached to:
  Serial.print(F("SSID: "));
  Serial.println(WiFi.SSID());
  // print your board's IP address:
  IPAddress ip = WiFi.localIP();
  Serial.print(F("IP Address: "));
  Serial.println(ip);
  // print the received signal strength:
  long rssi = WiFi.RSSI();
  Serial.print(F("signal strength (RSSI):"));
  Serial.print(rssi);
  Serial.println(" dBm");
void sendData(){
    initWifi();
  // if you get a connection, report back via serial:
  if (client.connected()) {
      Serial.println(F("Client connected to server"));
  if (client.connect(SERVER, PORT)) {
      Serial.println(F("connected to server"));
    // Make a HTTP request:
    dtostrf(ecs_high_temp,3,1,ecs_high_temp_s);
    dtostrf(ecs_low_temp,3,1,ecs_low_temp_s);
    dtostrf(solar_temp,3,1,solar_temp_s);
    dtostrf(solar_ret_temp,3,1,solar_ret_temp_s);
    dtostrf(ecs_in_temp,3,1,ecs_in_temp_s);
    dtostrf(pac_top_temp,3,1,pac_top_temp_s);
    dtostrf(pac_out_temp,3,1,pac_out_temp_s);
    sprintf(Send_URL, "GET /input/post?node=%s&json={ecs_high:%s,ecs_low:%s,solar_temp:%s,solar_ret:%s,HeatQuantity:%lu,PumpSpeed:%u,Relay:%u,ecs_in:%s,pac_top:%s,pac_out:%s,pompeStatus:%d}&apikey=29ceaa8fdad3f5268a2c1f7fd730ce2c HTTP/1.1\r\nHost:192.168.1.16\r\n\r\n",
NODE, ecs_high_temp_s,ecs_low_temp_s,solar_temp_s,solar_ret_temp_s,(HeatQuantity/1000),PumpSpeed1,Relay,ecs_in_temp_s,pac_top_temp_s,pac_out_temp_s,pompeStatus);
    client.println(Send_URL);
    Serial.println(Send_URL);
    delay(2000);
    while (client.available()) {
      char c = client.read();
      Serial.write(c);
    client.stop();
void wifiLowPower( bool lowPower) {
  if( lowPower) {
    setColor( 0,0,255); // blue until wifi is down
    Serial.println(F("WiFi lowPowerMode"));
    WiFi.lowPowerMode();
    setColor( 0,255,0); // blue until wifi is down
    Serial.println(F("WiFi nolowPowerMode"));
    WiFi.noLowPowerMode();
// set the RGB led
void setColor( uint8_t red, uint8_t green, uint8_t blue ) {
  WiFiDrv::analogWrite(25, green/20); // GREEN
  WiFiDrv::analogWrite(26, red/20); // RED
  WiFiDrv::analogWrite(27, blue/20); // BLUE
with the WebServer example you can test if the module has a problem or your sketch has a problem.
Thanks, but I don't see what the webserver code do that I don't!
My code is doing the same (about testing the wifi module) except that it's a client.
and here is what I send:
20:34:35.136 -> Host:192.168.1.16
20:34:35.136 ->
20:34:35.136 ->
20:34:37.083 -> HTTP/1.1 200 OK
20:34:37.116 -> Date: Tue, 27 Dec 2022 19:34:35 GMT
20:34:37.116 -> Server: Apache/2.4.53 (Debian)
20:34:37.116 -> Content-Length: 2
20:34:37.116 -> Content-Type: text/plain;charset=UTF-8
20:34:37.116 ->
And the server at the end is happy with that.
I send it every minute or so, and when I lost com to the module I have that:
20:35:37.353 -> Starting connection to server...
20:35:37.423 -> 255
20:35:37.453 -> Communication with WiFi module failed!
Using the webserver I have to find a computer that call it every 5 seconds, just to see if the module crash right ?
Are you thinking that a kind of buffer overflow that will crash the wifi module ?
you didn't post your sketch
As I said my skytch is 6 files, a little bit to much to publish, and I don't know how to push a zip files here, anyway if you want it her it is:
ECSnowifi.ino
#include "global.h"
#ifdef __arm__
// should use uinstd.h to define sbrk but Due causes a conflict
extern "C" char* sbrk(int incr);
#else  // __ARM__
extern char *__brkval;
#endif  // __arm__
  Serial.begin(57600);
  Serial.println(F("Controle solaire ECS"));
// Set RGB LED pin modes to output
  WiFiDrv::pinMode(25, OUTPUT);
  WiFiDrv::pinMode(26, OUTPUT);
  WiFiDrv::pinMode(27, OUTPUT);
// Set RGB LED color levels to zero for off, the max value is 128
  WiFiDrv::analogWrite(25, 0); // GREEN
  WiFiDrv::analogWrite(26, 0); // RED
  WiFiDrv::analogWrite(27, 0); // BLUE
  initLCD();
    // display information text
  lcd.setCursor(0, 0);
  lcd.print(F("Init Wifi..."));
  initWifi();
  lcd.setCursor(0, 1);
  lcd.print(F("Init vBus..."));
  // start the vBus.net
  initVbus();
  validData=false;
  lastPoolTimer = millis();
  lcd.setCursor(0, 2);
  lcd.print(F("Init PIN"));
// setup Transfert pump to output, and off
  pinMode(LED_BUILTIN, OUTPUT);
  digitalWrite(LED_BUILTIN, LOW);
  pinMode(TRANSFERTPUMP_PIN, OUTPUT);
  digitalWrite(TRANSFERTPUMP_PIN, LOW);
  ecs_in_temp=0.0;
  pac_out_temp=0.0;
  pac_top_temp=0.0;
  ecs_in.begin( MAX31865_2WIRE );
  pac_top.begin( MAX31865_2WIRE );
  pac_out.begin( MAX31865_2WIRE );
  lcd.print(ECS_IN_TEXT);
  lcd.print(PAC_TOP_TEXT);
  lcd.print(PAC_OUT_TEXT);
  setColor( 0,255,0);
// read the temperature
  if( Serial1.available() ) {
    if( readVbusValue() ) {
      validData=true;
  }  else {
    Serial.println(F("No value on vBus"));
  validData = true;
  // MAX31865
  Serial.println(F("Mesure MAX31865"));
  mesureValue();
  // display value all the time
  Serial.println(F("Display Value"));
  displayData();
  if( ( millis() - lastPoolTimer >= 60000 ) && validData ) {
  // if ok send it
    Serial.println(F("ok send it"));
    validData=false;
    lcd.setCursor(19, 0);
    lcd.print(F("*"));
    sendData();
    Serial.println(F("ok sended"));
    // check if we have to turn the pompe on or off
    if( ecs_high_temp >= TEMP_POMPE_ON && (pac_top_temp < ecs_high_temp || pac_top_temp < TEMP_MAX_PAC ) ) {
      pompeStatus = 1;
      digitalWrite(TRANSFERTPUMP_PIN, HIGH);
      digitalWrite(LED_BUILTIN, HIGH);
      pompeStatus = 0;
  delay(2000);
  lcd.print(F(" "));
global.h
#include <Adafruit_MAX31865.h>
#include <hd44780.h>
#include <hd44780ioClass/hd44780_pinIO.h> // Arduino pin i/o class header
#include <SPI.h>
#include <WiFiNINA.h>
#include <utility/wifi_drv.h>
char ssid[] = "closecontact";        // your network SSID (name)
char pass[] = "71776572747a75696f70313233";    // your network password (use for WPA, or use as key for WEP)
// wifi setting
int status = WL_IDLE_STATUS;
#define SERVER   "192.168.1.16"     // Host to contact
#define PORT     80                     // 80 = HTTP default port
#define NODE    "Solar"
// Initialize the Ethernet client library
// with the IP address and port of the server
// that you want to connect to (port 80 is default for HTTP):
WiFiClient client;
// vBus settings
double ecs_high_temp; // S3
double ecs_low_temp; // S2
double solar_temp; // S1
double solar_ret_temp; // S4
char ecs_high_temp_s[7]; // S3
char ecs_low_temp_s[7]; // S2
char solar_temp_s[7]; // S1
char solar_ret_temp_s[7];
uint8_t PumpSpeed1;  // in  %
char PumpSpeed2;  //  in %
char PumpSpeed3;  //  in %
uint8_t Relay;
char ErrorMask;
char Scheme;
uint32_t HeatQuantity;
char Send_URL[255];
// Settings for the VBus decoding
#define Sync  0xAA  // Synchronisation bytes
#define FrameLength 6   // Framelength
#define FrameOffset 10  // Offset start of Frames
#define FrameSeptet 4   // Septet byte in Frame
#define SENSORNOTCONNECTED 8888 // Sometimes this might be 888 instead.
unsigned int Destination_address;
unsigned int Source_address;
unsigned char ProtocolVersion;
unsigned int Command;
unsigned char Framecnt;
unsigned char Septet;
unsigned char Checksum;
unsigned long lastTimeTimer;
unsigned long timerInterval=7000;
// value from single sensor
float ecs_in_temp;
float pac_out_temp;
float pac_top_temp;
char ecs_in_temp_s[7];
char pac_out_temp_s[7];
char pac_top_temp_s[7];
bool pompeStatus;
#define RREF      4300.0
// The 'nominal' 0-degrees-C resistance of the sensor
#define RNOMINAL  1000.0
#define PAC_TOP_PIN A3
#define ECS_IN_PIN A4
#define PAC_OUT_PIN 3
// Use software SPI: CS, DI, DO, CLK
//Adafruit_MAX31865 thermo = Adafruit_MAX31865(10, 11, 12, 13);
// use hardware SPI, just pass in the CS pin
Adafruit_MAX31865 ecs_in = Adafruit_MAX31865(ECS_IN_PIN);
Adafruit_MAX31865 pac_top = Adafruit_MAX31865(PAC_TOP_PIN);
Adafruit_MAX31865 pac_out = Adafruit_MAX31865(PAC_OUT_PIN);
#define TRANSFERTPUMP_PIN 2
// defaut temp setting
#define TEMP_MAX_PAC        85 // temperature max de la PAC
#define TEMP_POMPE_ON       55 // Temperature de la consigne d'enclenchement de la pompe de circulation
bool all;
bool validData;
unsigned long lastPoolTimer;
// LCD settings
#define ECS_IN_TEXT   "ECS in: "
#define PAC_OUT_TEXT  "PAC out: "
#define PAC_TOP_TEXT  "PAC top: "
// with the arduino pin number it is connected to
#define D4_PIN 4
#define D5_PIN 5
#define D6_PIN 6
#define D7_PIN 7
#define RS_PIN A0
#define EN_PIN A1
#define BACKLIGHT_PIN A2
hd44780_pinIO lcd(RS_PIN, EN_PIN, D4_PIN, D5_PIN, D6_PIN, D7_PIN, BACKLIGHT_PIN, HIGH);
lcd.ino
void initLCD() {
  // set up the LCD's number of columns and rows:
  lcd.begin(20, 4);
  lcd.setBacklight(125);
// Turn off the cursor:
  lcd.noCursor();
void displayData() {
  lcd.setCursor(strlen(ECS_IN_TEXT), 0);
  lcd.print(ecs_in_temp, 1);
  lcd.setCursor(strlen(PAC_TOP_TEXT), 1);
  lcd.print(pac_top_temp, 1);
  lcd.setCursor(strlen(PAC_OUT_TEXT), 2);
  lcd.print(pac_out_temp, 1);
mesure.ino
void initMesure() {
  ecs_in.begin(MAX31865_2WIRE);
  pac_top.begin(MAX31865_2WIRE);
  pac_out.begin(MAX31865_2WIRE);
bool mesureValue() {
  bool ret;
  ecs_in_temp = ecs_in.temperature(RNOMINAL, RREF)-1.2;
  ret = checkError (ecs_in_temp);
  delay(100);
  pac_out_temp = pac_out.temperature(RNOMINAL, RREF)-1.2;
  ret = checkError (pac_out_temp);
  delay(100);
  pac_top_temp = pac_top.temperature(RNOMINAL, RREF)-1.2;
  ret = checkError (pac_top_temp);
  delay(100);
bool checkError( Adafruit_MAX31865 temp) {
  uint8_t fault;
  bool ret=false;
  fault = temp.readFault();
  if (fault)
    Serial.print(F("Fault 0x"));
    Serial.println(fault, HEX);
    if (fault & MAX31865_FAULT_HIGHTHRESH) {
      Serial.println(F("RTD High Threshold  "));
      lcd.setCursor(0, 3);
      lcd.print(F("RTD High Threshold  "));
    if (fault & MAX31865_FAULT_LOWTHRESH) {
      Serial.println(F("RTD Low Threshold   "));
      lcd.print(F("RTD Low Threshold   "));
    if (fault & MAX31865_FAULT_REFINLOW) {
      Serial.println(F("REFIN >0.85 x Bias  "));
      lcd.print(F("REFIN >0.85 x Bias  "));
    if (fault & MAX31865_FAULT_REFINHIGH) {
      Serial.println(F("REFIN <0.85 x Bias o"));
      lcd.print(F("REFIN <0.85 x Bias o"));
    if (fault & MAX31865_FAULT_RTDINLOW) {
      Serial.println(F("RTDIN <0.85 x Bias o"));
      lcd.print(F("RTDIN <0.85 x Bias o"));
    if (fault & MAX31865_FAULT_OVUV) {
      Serial.println(F("Under/Over voltage  "));
      lcd.print(F("Under/Over voltage  "));
    temp.clearFault();
    delay(2000);
    lcd.print(F("                    "));
  } else ret=true;
  return ret;
vbus.ino
67. DFA (0x0010) <= SOLTOP DeltaSol S2/S3 (0x7731)
Offset Size Mask             Name        Factor Unit
0                             2                                             Temperature sensor 1 0.1          °C
2                             2                                             Temperature sensor 2 0.1          °C
Frame 2
4                             2                                             Temperature sensor 3 0.1          °C
6                             2                                             Temperature sensor 4 0.1          °C
Frame 3
8                             2                                             Temperature sensor 5 0.1          °C
10                           2                                              Temperature sensor 6 0.1          °C
Frame 4
12                           2                                              Temperature sensor 7 0.1          °C
14                           2                                              Temperature sensor 8 0.1          °C
Frame 5
16                           1                                              Pump speed R1                                               1                             %
17                           1                                              Pump speed R2                                               1                             %
18                           1                                              Pump speed R3                                               1                             %
19                           1                                              Relay byte                                                         1
Frame 6
20                           2                                              Heat        1                             Wh
22                           2                                              Heat        1000      Wh
Frame 7
24                           2                                              Heat        1000000 Wh
26                           1                                              Scheme        1
unsigned char Buffer[80];
volatile unsigned char Bufferlength;
void initVbus(){
  Serial1.begin(9600);
  Serial.println(F("vBus Serial open"));
  solar_temp=0.0; // S1
  ecs_low_temp=0.0; // S2
  ecs_high_temp=0.0; // S3
  solar_ret_temp=0.0; // S4
bool readVbusValue() {
    char c;
    bool start,stop,quit;
    start = true;
    stop = false;
    quit = false;
    Bufferlength=0;
    lastTimeTimer = 0;
    lastTimeTimer = millis();
    memset( Buffer,0, sizeof(Buffer));
  Serial.println(F("vBus read"));
  while ((!stop) and (!quit))  {
    if (Serial1.available()) {
      c=Serial1.read();
      if (c == Sync || c == 0xFFFFFFAA ) {
        if (start) {
          start=false;
          Bufferlength=0;
          if (Bufferlength<20) {
            lastTimeTimer = 0;
            Bufferlength=0;
          } else
            stop=true;
      if ((!start) and (!stop)) {
        Buffer[Bufferlength]=c;
        Bufferlength++;
    } // end if mySerial.available
    if ((timerInterval > 0) &&  (millis() - lastTimeTimer > timerInterval ) ) {
      quit=true;
  } // end while loop
  lastTimeTimer = 0;
Serial.println( F("Buffer: "));
for( int i=0;i <= Bufferlength; i++ ) {
  Serial.print( Buffer[i], HEX);
  Serial.print( " " );
Serial.println(F("End Buffer") );
  if (!quit) {
    Destination_address = Buffer[2] << 8;
    Destination_address |= Buffer[1];
    Source_address = Buffer[4] << 8;
    Source_address |= Buffer[3];
    ProtocolVersion = (Buffer[5]>>4) + (Buffer[5] &(1<<15));
    Command = Buffer[7] << 8;
    Command |= Buffer[6];
    Framecnt = Buffer[8];
    Checksum = Buffer[9];  //TODO check if Checksum is OK
    Serial.println(F("---------------"));
    Serial.print(F("Destination: "));
    Serial.println(Destination_address, HEX);
    Serial.print(F("Source: "));
    Serial.println(Source_address, HEX);
    Serial.print(F("Protocol Version: "));
    Serial.println(ProtocolVersion);
    Serial.print(F("Command: "));
    Serial.println(Command, HEX);
    Serial.print(F("Framecount: "));
    Serial.println(Framecnt);
    Serial.print(F("Checksum: "));
    Serial.println(Checksum);
    Serial.print(F("Bufferlength: "));
    Serial.println(Bufferlength);
15:38:33.340 -> Destination: 10
15:38:33.340 -> Source: 7731
15:38:33.340 -> Protocol Version: 1
15:38:33.340 -> Command: 100
15:38:33.340 -> Framecount: 7
15:38:33.378 -> Checksum: 47
15:38:33.378 -> Bufferlength: 52  Sometime 38 why
  // Only analyse Commands 0x100 = Packet Contains data for slave
  // with correct length = 10 bytes for HEADER and 6 Bytes  for each frame
  // Buffer length has to be 52 to be correct (7*6=42 + 10=52)
//    if ((Command==0x0100) and (Bufferlength==10+Framecnt*6)) {
    if ( (Command==0x0100) ) {
      //Only decode the data from the correct source address
      //(There might be other VBus devices on the same bus).
      decodeVbusFrame(Buffer);
      Serial.println(F("------Values------"));
      Serial.print(F("Solar : "));
      Serial.println(solar_temp);
      Serial.print(F("ECS Low: "));
      Serial.println(ecs_low_temp);
      Serial.print(F("ECS High: "));
      Serial.println(ecs_high_temp);
      Serial.print(F("Solar return: "));
      Serial.println(solar_ret_temp);
      Serial.print(F("Pump speed1: "));
      Serial.println(PumpSpeed1, HEX);
      Serial.print(F("Pump speed2: "));
      Serial.println(PumpSpeed2, HEX);
      Serial.print(F("Pump speed3: "));
      Serial.println(PumpSpeed3, HEX);
      Serial.print(F("Relay: "));
      Serial.println(Relay, HEX);
      Serial.print(F("Heat: "));
      Serial.println(HeatQuantity);
      Serial.print(F("Scheme: "));
      Serial.println(Scheme, HEX);
14:56:55.174 -> Pump speed1: 64
14:56:55.174 -> Pump speed2: 64
14:56:55.174 -> Pump speed3: 0
14:56:55.174 -> Relay: 6
32'390,643
afficher 32 390 KWH
      Serial.println(F("Error vBus "));
      return false;
  return true;
void decodeVbusFrame( unsigned char *frame ){
  int FO;
//  Serial.println(F("Now decoding for 0x7731"));
  FO=FrameOffset;
  Septet=frame[FO+FrameSeptet];
  InjectSeptet(frame,FO,4);
  solar_temp = CalcTemp(frame[FO+1], frame[FO]);
  ecs_low_temp = CalcTemp(frame[FO+3], frame[FO+2]);
18:50:22.981 -> Solar : 7.80
18:50:22.981 -> ECS Low: 26.30
  //*******************  Frame 2  *******************
  FO=FrameOffset+FrameLength;
  Septet=Buffer[FO+FrameSeptet];
  ecs_high_temp = CalcTemp(frame[FO+1], frame[FO]);
  solar_ret_temp = CalcTemp(frame[FO+3], frame[FO+2]);
18:50:22.981 -> ECS High: 44.80
18:50:22.981 -> Solar return: 21.10
  //*******************  Frame 3  *******************
  FO=FrameOffset+FrameLength+2;
Serial.print("Temp5 : ");
Serial.println(CalcTemp(frame[FO+1], frame[FO]));
Serial.print("Temp6 : ");
Serial.println(CalcTemp(frame[FO+3], frame[FO+2]));
//*******************  Frame 4  *******************
  FO=FrameOffset+FrameLength+3;
Serial.print("Temp7 : ");
Serial.print("Temp8 : ");
//*******************  Frame 5  *******************
  FO=FrameOffset+FrameLength*4;
  PumpSpeed1 = (frame[FO] & 0X7F);
  PumpSpeed2 = (frame[FO+1] & 0X7F);
  PumpSpeed3 = (frame[FO+2] & 0X7F);
  Relay = frame[FO+3];
  if( Relay == 6 ) Relay = 1; // 2 chauffage bas
Serial.println( F("Frame 5"));
Serial.println( frame[FO], HEX);
Serial.println( frame[FO+1], HEX);
Serial.println( frame[FO+2], HEX);
Serial.println( frame[FO+3], HEX);
18:50:29.213 -> 0
18:50:29.213 -> 0
18:50:29.213 -> 0
18:50:29.213 -> 0
  //*******************  Frame 6  *******************
  FO=FrameOffset+FrameLength*5;
  HeatQuantity=(frame[FO+1] << 8 | frame[FO])+(frame[FO+3] << 8| frame[FO+2])*1000;
Serial.println( F("Frame 6"));
18:50:29.213 -> D5
18:50:29.213 -> 0
18:50:29.213 -> 6
18:50:29.213 -> 1
  //*******************  Frame 7  *******************
  FO=FrameOffset+FrameLength*6;
  HeatQuantity=HeatQuantity+(frame[FO+1] << 8 | frame[FO])*1000000;
  Scheme    =  frame[FO+2];
Serial.println( F("Frame 7"));
 * 32'390,643
afficher 32 390 KWH
18:50:29.213 -> 20
18:50:29.213 -> 0
18:50:29.213 -> 3
// The following is needed for decoding the data
void  InjectSeptet(unsigned char *Buffer, int Offset, int Length) {
  for (unsigned int i = 0; i < Length; i++) {
    if (Septet & (1 << i)) {
      Buffer [Offset + i] |= 0x80;
// This function converts 2 data bytes to a temperature value.
float CalcTemp(int Byte1, int Byte2) {
  int v;
  v = Byte1 << 8 | Byte2; //bit shift 8 to left, bitwise OR
  if (Byte1 == 0x00){
    v= v & 0xFF;
  if (Byte1 == 0xFF)
    v = v - 0x10000;
  if (v==SENSORNOTCONNECTED)
    v=0;
  return (float)((float) v * 0.1);
wifi.ino
void initWifi(){
    // don't continue
    while (true);
  Serial.println(fv);
    delay(5000);
  printWifiStatus();
  setColor( 0,255,0);
  Serial.println(ip);
  Serial.print(rssi);
void sendData(){
    initWifi();
    delay(2000);
      Serial.write(c);
    client.stop();
  if( lowPower) {
// set the RGB led
it is more important what you code does what the webserver code doesn't
it is not ideal, but it is not not that bad that it can't run 30 minutes. so the problem is with your code
