Hello
I am trying to compile the recomended example sketch from the Blynk Library to my Arduino UNO Wifi rev2.
Following Error appears:
Arduino: 1.8.19 (Windows Store 1.8.57.0) (Windows 10), Board: "Arduino Uno WiFi Rev2, None (ATMEGA4809)"
In file included from C:\Users\Documents\Arduino\libraries\blynk-library-master\src/Blynk/BlynkApi.h:36:0,
from C:\Users\Documents\Arduino\libraries\blynk-library-master\src/BlynkApiArduino.h:14,
from C:\Users\Documents\Arduino\libraries\blynk-library-master\src/Adapters/BlynkWiFiCommon.h:24,
from C:\Users\Documents\Arduino\libraries\blynk-library-master\src/BlynkSimpleWiFiNINA.h:22,
from C:\Users\SVENBU~1\AppData\Local\Temp\arduino_modified_sketch_998524\Arduino_MKR1010.ino:36:
C:\Users\Documents\Arduino\libraries\blynk-library-master\src/Blynk/BlynkParam.h: In member function 'long long int BlynkParam::iterator::asLongLong() const':
C:\Users\Documents\Arduino\libraries\blynk-library-master\src/Blynk/BlynkParam.h:48:50: error: 'atoll' was not declared in this scope
long long asLongLong() const { return atoll(ptr); }
C:\Users\Documents\Arduino\libraries\blynk-library-master\src/Blynk/BlynkParam.h:48:50: note: suggested alternative: 'atol'
atol
C:\Users\Documents\Arduino\libraries\blynk-library-master\src/Blynk/BlynkParam.h: In member function 'long long int BlynkParam::asLongLong() const':
C:\Users\Documents\Arduino\libraries\blynk-library-master\src/Blynk/BlynkParam.h:89:46: error: 'atoll' was not declared in this scope
long long asLongLong() const { return atoll(buff); }
C:\Users\Documents\Arduino\libraries\blynk-library-master\src/Blynk/BlynkParam.h:89:46: note: suggested alternative: 'atol'
atol
exit status 1
Error compiling for board Arduino Uno WiFi Rev2.
I want to compile the following Example Sketch:
#define BLYNK_PRINT Serial
/* Fill-in your Template ID (only if using Blynk.Cloud) */
#define BLYNK_TEMPLATE_ID "TMPLVFNNCOih"
#include <SPI.h>
#include <WiFiNINA.h>
#include <BlynkSimpleWiFiNINA.h>
// You should get Auth Token in the Blynk App.
// Go to the Project Settings (nut icon).
char auth[] = "MyAuth";
// Your WiFi credentials.
// Set password to "" for open networks.
char ssid[] = "ssid";
char pass[] = "password";
// Debug console
Blynk.begin(auth, ssid, pass);
// You can also specify server:
//Blynk.begin(auth, ssid, pass, "blynk-cloud.com", 80);
//Blynk.begin(auth, ssid, pass, IPAddress(192,168,1,100), 8080);
Blynk.run();
Does anyone understand this error??
Thanks for helping
Sven
