Hello,
Please can someone help me diagnose this list of errors.
I am trying to get Arduino UNO Wifi Rev2 to work with Blynk.
Here's the code
#define BLYNK_PRINT Serial
#include <SPI.h>
#include <WiFiNINA.h>
#include <BlynkSimpleWiFiNINA.h>
// You should get Auth Token in the Blynk App.
// Go to the Project Settings (nut icon).
char auth[] = "6**************************e";
// Your WiFi credentials.
// Set password to "" for open networks.
char ssid[] = "iPhone von M*****";
char pass[] = "g*************";
//char ssid[] = "G*************";
//char pass[] = "m***********";
// Debug console
Blynk.begin(auth, ssid, pass);
// You can also specify server:
//Blynk.begin(auth, ssid, pass, "blynk-cloud.com", 80);
//Blynk.begin(auth, ssid, pass, IPAddress(192,168,1,100), 8080);
// This function will be called every time Slider Widget
// in Blynk app writes values to the Virtual Pin 1
BLYNK_WRITE(V1)
int pinValue = param.asInt(); // assigning incoming value from pin V1 to a variable
// You can also use:
// String i = param.asStr();
// double d = param.asDouble();
Serial.print("V1 Slider value is: ");
Serial.println(pinValue);
Blynk.run();
All I'm trying to do at the moment is compile in the editor (v1.8.12), board set to Arduino UNI WiFi 2.
I get these errors:
C:\Users\mwclubb04\Documents\Arduino\libraries\WiFiNINA\src\utility\spi_drv.cpp: In static member function 'static void SpiDrv::begin()':
C:\Users\mwclubb04\Documents\Arduino\libraries\WiFiNINA\src\utility\spi_drv.cpp:87:24: error: 'PINS_COUNT' was not declared in this scope
if (SLAVERESET > PINS_COUNT) {
C:\Users\mwclubb04\Documents\Arduino\libraries\WiFiNINA\src\utility\spi_drv.cpp:87:24: note: suggested alternative: 'PING_CMD'
PING_CMD
C:\Users\mwclubb04\Documents\Arduino\libraries\WiFiNINA\src\utility\spi_drv.cpp:97:15: error: 'NINA_GPIO0' was not declared in this scope
pinMode(NINA_GPIO0, OUTPUT);
C:\Users\mwclubb04\Documents\Arduino\libraries\WiFiNINA\src\utility\spi_drv.cpp: In static member function 'static int SpiDrv::available()':
C:\Users\mwclubb04\Documents\Arduino\libraries\WiFiNINA\src\utility\spi_drv.cpp:565:25: error: 'NINA_GPIO0' was not declared in this scope
return (digitalRead(NINA_GPIO0) != LOW);
exit status 1
Error compiling for board Arduino Uno WiFi.
Thanks
