Arduino Uno wifi Shield No socket available
I need to make requests to a laravel api, but when I try to make a connection client.connect(server, 8000)
I get the error "no socket available".
#include <WiFi.h>
char ssid[] = "****";     //  your network SSID (name)
char pass[] = "*****";    // your network password
int status = WL_IDLE_STATUS;     // the Wifi radio's status
char server[] = "ip";
WiFiClient client;
//pines donde estan conectados los sensores
int MQ_3 = A0;
int MQ_2 = A1;
int MQ_135 = A2;
const int MQ_DELAY = 500;
  // initialize serial:
  // attempt to connect using WPA2 encryption:
  Serial.println("Attempting to connect to WPA network...");
  status = WiFi.begin(ssid, pass);
  // if you're not connected, stop here:
  if ( status != WL_CONNECTED) {
    Serial.println("Couldn't get a wifi connection");
    while(true);
  // if you are connected, print out info about the connection:
  else {
    Serial.println("Connected to network");
  if(client.connect(server, 8000)){
    Serial.println("connected to server");
    //Make a HTTP request:
    client.println("GET /api/sensores/?q1=100&q2=200&q335=300 HTTP/1.1");
    client.println("Host: 192.0.0,0");
    client.println("Connetion: close");
    client.println();
  // do nothing
  int resmq2 = analogRead(MQ_2);
  int resmq3 = analogRead(MQ_3);
  int resmq135 = analogRead(MQ_135);
  delay(MQ_DELAY);
    String resultado = String("q1=")+resmq2+String("&q2=")+resmq3+String("&q3=")+resmq135;
    //HTTP request
    client.println("GET /api/sensores/?"+resultado+" HTTP/1.1");
    client.println("Host: 192.0.0.0");
    client.println();
    char c = client.read();
    Serial.write(c);
  delay(5000);
add client.stop();
Where?
I was try whit a client.flush and client.Close before the line if(client.conect()) but not work
Thanks
