Arduino Uno WiFi to Adafruit Feather BLE
Hi all!
I've been working on a project involving both an Arduino Uno WiFi (peripheral and server) and Adafruit Feather (central and client). I'm using the Feather essentially as a Serial to BLE bridge which either inputs BLE data from a peripheral into MAX/MSP and Ableton and also allows me to send serial data out and back to specified connected peripherals. The code is provided below.
I've been able to successfully send data generated on the Arduino to the Feather using the Notify function for a while now with no issue. I'm trying to also send data out of Ableton/Max and to connected peripherals that will control a Neopixel strip by providing information about tempo, subdivision, amount of octaves, etc. for different VSTs.
For the time being I'm just trying to test the bare minimum and make sure I can send data from the Feather to the Arduino before messing around with serial data. I'm currently doing this by generating random numbers and writing to the characteristic on the peripheral. However, I'm running into the issue that the peripheral is not receiving any of the info. On the central side it's saying that the characteristic is written to, but the callback for the peripheral never fires and it says that the characteristic is not writable. I am obviously misunderstanding some functions, but I cannot wrap my head around this. The characteristic is allowed to be write only as I never need the Feather to read anything off that specific characteristic. Any help would be greatly appreciated!
Arduino Code - - -
const int VSTsize = 1;
BLEService buttonService("62757474-6F6E-7320-746F-6F206D696469");                                   //Service UUID
BLECharacteristic ArpeggiatorChr("56535449-6E66-6F72-6D61-74696F6E0000", BLEWrite, VSTsize, true);  //UUID, Properties, array size, true = size does not change
  if (!BLE.begin()) {
    Serial.println("starting BLE failed");
    while (1)
  BLE.setLocalName("Buttons");
  BLE.setAdvertisedService(buttonService);
  buttonService.addCharacteristic(ArpeggiatorChr);
  BLE.addService(buttonService);
  BLE.setEventHandler(BLEConnected, bleConnected);                    //connected callback
  BLE.setEventHandler(BLEDisconnected, bleDisconnected);              //disconnected callback
  ArpeggiatorChr.setEventHandler(BLEWritten, ArpeggiatorChrWritten);  //Characteristic written to callback
  ArpeggiatorChr.writeValue(0);  //inital value
  BLE.advertise();
  BLEDevice central = BLE.central();
  if (central) {
    digitalWrite(LED_BUILTIN, HIGH);  //device is connected
    while (central.connected()) {
      if (ArpeggiatorChr.canWrite()) {               //can the characteristic be written to?
        Serial.println("Characteristic writable!");  //Yes!
        Serial.println("Characteristic NOT writable!");  //No!
    static unsigned long previousMillis = 0;
    int changeTime = 500;
    static int ledState = LOW;
    if (currentMillis - previousMillis >= changeTime) {  //device disconnected, LED blinks
      if (ledState == LOW) {
        ledState = HIGH;
        ledState = LOW;
      digitalWrite(LED_BUILTIN, ledState);
void bleConnected(BLEDevice central) {
  Serial.print("Connected event, central: ");
  Serial.println(central.address());
void bleDisconnected(BLEDevice central) {
  Serial.print("Disconnected event, central: ");
void ArpeggiatorChrWritten(BLEDevice central, BLECharacteristic characteristic) {
  Serial.println("Characteristic written to!");  //lets user know device was written to
Adafruit Feather Code - - -
#include <bluefruit.h>
int MAX_CONNECTION_COUNT = 2;  // total # of possible connections
int CURRENT_CONNECTION_COUNT = 0;
const uint8_t BUTTONS_UUID_SERVICE[] = {  //Service UUID
  0x69, 0x64, 0x69, 0x6D, 0x20, 0x6F, 0x6F, 0x74,
  0x20, 0x73, 0x6E, 0x6F, 0x74, 0x74, 0x75, 0x62
const uint8_t ARP_UUID_CHARACTERISTIC[] = {  //Characteristic UUID
  0x00, 0x00, 0x6E, 0x6F, 0x69, 0x74, 0x61, 0x6D,
  0x72, 0x6F, 0x66, 0x6E, 0x49, 0x54, 0x53, 0x56
BLEClientService Buttons = BLEClientService(BUTTONS_UUID_SERVICE);                          //Add UUID to service
BLEClientCharacteristic ArpeggiatorChr = BLEClientCharacteristic(ARP_UUID_CHARACTERISTIC);  //Add UUID to characteristic
  Bluefruit.begin(0, MAX_CONNECTION_COUNT);
  Bluefruit.setName("Bluefruit52 Central");
  Buttons.begin();         //Begin service
  ArpeggiatorChr.begin();  //Add characteristic to buttons service
  Bluefruit.autoConnLed(true);
  Bluefruit.Central.setDisconnectCallback(disconnect_callback);
  Bluefruit.Central.setConnectCallback(connect_callback);
  Bluefruit.Scanner.setRxCallback(scan_callback);
  Bluefruit.Scanner.restartOnDisconnect(true);
  Bluefruit.Scanner.setInterval(160, 80);
  Bluefruit.Scanner.filterUuid(Buttons.uuid);  //filter specifically for service UUID
  Bluefruit.Scanner.useActiveScan(false);
  Bluefruit.Scanner.start(0);
  uint8_t randNumber[1];
  randNumber[0] = random(100);
  Serial.println(randNumber[0]);  //generate random number, store in buffer, print out for own sake
  if (Bluefruit.connected()) {                       //if connected to peripheral
    if (ArpeggiatorChr.write(randNumber, 1)) {       //write buffer to characteristic
      Serial.println("Characteristic written to!");  //it's been written to!
      Serial.println("Characteristic NOT written to!");  //it was not written to!
 * @param report
void scan_callback(ble_gap_evt_adv_report_t* report) {
  Bluefruit.Central.connect(report);
 *@param conn_handle
void connect_callback(uint16_t conn_handle) {
  Serial.println("Connecting");  //finds service and characteristic and initiates connection, otherwise drops connection if proper UUID's aren't found
  Serial.print("Discovering Button Service ...");
  if (!Buttons.discover(conn_handle)) {
    Serial.println("Found None");
    Bluefruit.disconnect(conn_handle);
    return;
  if (Buttons.discover(conn_handle)) {
    Serial.println("Buttons Found!");
    Serial.println("Discovering Characteristic ... ");
    if (!ArpeggiatorChr.discover()) {
      Serial.println("Arpeggiator Characteristic not found!");
      return;
      Serial.println("Found Characteristic, ready to write to!");
 * @param conn_handle
 * @param reason
void disconnect_callback(uint16_t conn_handle, uint8_t reason) {
  (void)conn_handle;
  (void)reason;
  Serial.print("Disconnected, reason = 0x");
  Serial.println(reason, HEX);
  if (CURRENT_CONNECTION_COUNT = MAX_CONNECTION_COUNT) {
  CURRENT_CONNECTION_COUNT--;
