ARDUINO UNO WIFI WiFi client
Arduino UNO WIFI
Hello All,
Please , what is the library for arduino UNO WIFI , to connect to a http server ? I’m using WiFi.h but it doesn’t work, I continue to receive the status of connecting… in loop so no wifi connection. Arduino is already connected to my wifi with a static address.
That is the sketch. any suggestion ? Thanks in advance… Best regards
#include <WiFi.h>
#include <SPI.h>
#include <OneWire.h>
#include <AESLib.h>
char ssid[] = "myWifi";
char pass[] = "password";
char server[] = "myhttpserver";
OneWire  ds(8);  // on pin 10 (a 4.7K resistor is necessary)
WiFiClient client;
int status = WL_IDLE_STATUS;
void setup(void) {
 while(status != WL_CONNECTED){
   Serial.println("Connecting...");
   status = WiFi.begin(ssid,pass);
   delay(10000);
void loop(void) {
 byte i;
 byte present = 0;
 byte type_s;
 byte data[12];
 byte addr[8];
 float celsius, fahrenheit;
 if (!ds.search(addr)) {
   Serial.println("No more addresses.");
   ds.reset_search();
   delay(250);
   return;
 Serial.print("ROM =");
 for( i = 0; i < 8; i++) {
   Serial.write(' ');
   Serial.print(addr[i], HEX);
 if (OneWire::crc8(addr, 7) != addr[7]) {
     Serial.println("CRC is not valid!");
     return;
 // the first ROM byte indicates which chip
 switch (addr[0]) {
   case 0x10:
     Serial.println("  Chip = DS18S20");  // or old DS1820
     type_s = 1;
   case 0x28:
     Serial.println("  Chip = DS18B20");
     type_s = 0;
   case 0x22:
     Serial.println("  Chip = DS1822");
     type_s = 0;
   default:
     Serial.println("Device is not a DS18x20 family device.");
     return;
 ds.reset();
 ds.select(addr);
 ds.write(0x44, 1);        // start conversion, with parasite power on at the end
 delay(1000);     // maybe 750ms is enough, maybe not
 // we might do a ds.depower() here, but the reset will take care of it.
 present = ds.reset();
 ds.select(addr);
 ds.write(0xBE);         // Read Scratchpad
 Serial.print("  Data = ");
 Serial.print(present, HEX);
 Serial.print(" ");
 for ( i = 0; i < 9; i++) {           // we need 9 bytes
   data[i] = ds.read();
   Serial.print(data[i], HEX);
   Serial.print(" ");
 Serial.print(" CRC=");
 Serial.print(OneWire::crc8(data, 8), HEX);
 // Convert the data to actual temperature
 // because the result is a 16 bit signed integer, it should
 // be stored to an "int16_t" type, which is always 16 bits
 // even when compiled on a 32 bit processor.
 int16_t raw = (data[1] << 8) | data[0];
 if (type_s) {
   raw = raw << 3; // 9 bit resolution default
   if (data[7] == 0x10) {
     // "count remain" gives full 12 bit resolution
     raw = (raw & 0xFFF0) + 12 - data[6];
   byte cfg = (data[4] & 0x60);
   // at lower res, the low bits are undefined, so let's zero them
   if (cfg == 0x00) raw = raw & ~7;  // 9 bit resolution, 93.75 ms
   else if (cfg == 0x20) raw = raw & ~3; // 10 bit res, 187.5 ms
   else if (cfg == 0x40) raw = raw & ~1; // 11 bit res, 375 ms
   //// default is 12 bit resolution, 750 ms conversion time
 celsius = (float)raw / 16.0;
 Serial.print("  Temperature = ");
 Serial.print(celsius);
 Serial.println(" Celsius, ");
 Serial.println(WiFi.SSID());
 if (client.connect(server,80)){
   client.print("GET ");
   client.print("/arduino/temperature.php?t1=");
   client.print(celsius);
   client.println(" HTTP/1.0");
   client.print("Host: ");
   client.println(server);
   client.println("Cache-Control: no-cache");
   client.println("Connection: close");
   client.println();
     Serial.println("Connection failed");
...and that's why we ask you to use code tags when posting code
AWOL: ...and that's why we ask you to use code tags when posting code
Done! Sorry I forgot to put it
